Can't reconnect to router after router reset
A
Akira
Whenever I lose my wireless connection to my router (I connect to a Linksys
Wireless G router), I'm not able to reconnect to it unless I restart my
computer completely. The reason I can't connect is that it says my wireless
security key is incorrect, and even when re-typing in the security key it
will always say it is incorrect until I restart my computer. I was wondering
if anyone can shed some light on why this is occuring and how I can go about
fixing it. For a wireless network card, I use a Compact Wireless-G USB
adapter.
B
Barb Bowman
what model and hardware version linksys G router? what firmware?
what driver for the USB wireless adapter?
do you have an IP when in this state? do you have an IP but no
gateway? (if yes, is
http://support.microsoft.com/default.aspx/kb/933872/en-us your
problem)
need more information to assist you with this.
On Fri, 27 Jul 2007 19:34:01 -0700, Akira
>adapter.
Barb Bowman
MS Windows-MVP
http://www.microsoft.com/windowsxp/expertzone/meetexperts/bowman.mspx
http://blogs.digitalmediaphile.com/barb/
A
Akira
Thanks for the help. I don't have an IP when in this state. I'm downloading
the update you linked for me and I hope it works =).
> problem)
> >adapter.
> Barb Bowman
> MS Windows-MVP
B
Barb Bowman
please post results here.
On Wed, 1 Aug 2007 04:12:02 -0700, Akira
>> problem)
>> >adapter.
>> Barb Bowman
>> MS Windows-MVP
Barb Bowman
MS Windows-MVP
