Caps Lock problems
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
The Caps Lock key drives me nuts. I often find that I have typed several
lines in caps, where it wasn't intended.
In Win XP, I could fix things easily so that the Shift key did turn off
the Caps Lock:
Shift to Turn Off Caps
How do I go about it in Vista?
TIA
Roger.
Hi Roger,
This is not the same thing, but you may find it helpful. It will show you how to turn on the beep alert for the toggle keys. This way the computer will beep at you when any of the toggle keys are pressed, or the Caps Lock key is bumped by mistake.
http://www.vistax64.com/tutorials/74689-toggle-keys-beep-alert.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
K
Ken Blake, MVP
On Tue, 25 Dec 2007 21:00:17 +0100, Roger Van Loon
> the Caps Lock:
> http://pubs.logicalexpressions.com/pub0009/LPMArticle.asp?ID=389
There are two keys I never use on purpose and always want turned off.
One is the caps lock key, and the other is the Insert key. I turn both
off with the little program SharpKeys, at
http://www.randyrants.com/sharpkeys/
Ken Blake, Microsoft MVP Windows - Shell/User
Please Reply to the Newsgroup
D
Dave Horne
Depending on the driver software for your particular keyboard, the Caps lock
could also be turned off there. I use a cordless Logitech mouse and
keyboard (MX3000) and have the Caps lock turned off via Logitech's software
(accessed via the System Tray).
"Roger Van Loon" <roger.van.loon@xxxxxx> wrote in message
news:u1Tp8CzRIHA.536@xxxxxx
> the Caps Lock:
> TIA
> Roger.
R
Roger Van Loon
Having used a regular typewriter for many decades, where the shift key
turns off caps lock, I always did set up Windows to act that same way. I
will have some difficulties adapting to other settings, would like very
much to keep the same setup. However, I suppose that is no longer
possible in Vista.
Thanks, all.
Roger.
> several lines in caps, where it wasn't intended.
> off the Caps Lock:
> TIA
> Roger.
