Capture command result
B
Bruce Wilkinson
How do a capture the result of a command in a script? For example, the
following will return the file last written, dir | sort -prop LastWriteTime |
select -last 1. How do I save that so I can later use the name?
Bruce
R
RichS
Could try something like this
PS> $t = dir | sort -prop LastWriteTime | select -last 1
PS> $t.name
test1
PS>
Richard Siddaway
Please note that all scripts are supplied "as is" and with no warranty
> Bruce
A
Andrew Watt [MVP]
On Tue, 19 Dec 2006 08:30:00 -0800, Bruce Wilkinson
>Bruce
Bruce,
I assume you want to save the information in a file. If not then
simply assign it to a variable as in the first line of code which
follows.
The following works for me.
$a = dir | sort -prop LastWriteTime | select-object -Last 1
$a > C:\Last.txt
NOTE: The following does NOT work. At least it doesn't work as
expected for me.
(dir | sort -prop LastWriteTime | select-object -Last 1) > C:\Last.txt
Andrew Watt MVP
