catch array from pipe
R
hello,
i have a script to sign file. but it will only sign the last file passed
down. (ls *.ps1 | sign) ps didn't show any syntax error. could you help
point it out?
function global:sign {
param(
[Parameter(mandatory=$true,ValueFromPipeline=$true)][System.io.fileinfo[]]$fileList
foreach ( $file in $fileList ) {
set-authenticodesignature -filepath $file -certificate ( ls
cert:\CurrentUser\my -codesigning );
S
I think this is a common trap (at least for me). You have to specify
in the function that the block of code is process part:
param([Parameter(mandatory=$true,ValueFromPipeline=$true)]
[System.io.fileinfo[]]$fileList)
process {
set-authenticodesignature -filepath $file -certificate ( ls cert:
On Feb 23, 9:51 am, ryan <r...@newsgroup> wrote:
> hello,
> point it out?
>    param(
R
thank you
> process {
> On Feb 23, 9:51 am, ryan<r...@newsgroup> wrote:
>> hello,
>> point it out?
>> param(
