change default icons
M
Hi guys,
I have downloaded a icon package for vista with very smooth icons.
I know how to change a program or folder icon or a indivudally file icon in
the items properties but
how do I assign a new icon to be used as a default for example word
documents, mp3 and such
so all my mp3 files and such are showing the new icon?
If it have something so say I'm using vista 64 bit ultimative sp1
Greatful for help
All the best
Mike (n00b)
G
Guest
Type regedit in Start's search box.
and see that it's default value is Paint.Picture so lookup
HKEY_CLASSES_ROOT\Paint.Picture\DefaultIcon
"Mike" <mike@newsgroup> wrote in message
news:%23solO9bPKHA.3876@newsgroup
> Hi guys,
> in the items properties but
> Greatful for help
> All the best
> Mike (n00b)
G
Guest
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\explorer\Shell
Icons]
"Number from list below"="Path to icon, Icon index"
The list below specifies the number for the default shell icons.
The path to icon is a dos path to the icon, in a registry file remembe to
use \\ (regedit rmoves one \ when merging).
The icon index is used when the icons are coming from a binary file like a
..dll or .exe. It is the position of the icon in the file (a negitive number
is the inverse of the resource ID). Omit the comma and Icon Index when using
an .ICO file.
To get the index create a shortcut, right click and choose Properties, then
Change Icon, then Browse. Select the file and click open. The icons are
numbered from 0 downwards then across.
Icons can also be set under the Default Icon setting for the object in
HKEY_ROOT (which is where Windows stores its' icon information), the Shell
Icon setting overrides this.
Value Description
0 Unknown File Type
1 Default Document
2 Default Application
3 Folder
4 Open Folder
5 5.25 inch Floppy
6 3.5 inch Floppy
7 Removable Drive
8 Hard Drive
9 Network Drive
10 Network Disconnected
11 Cd-rom Drive
12 Ram Drive
13 Globe
14 Network Pipes ?
15 Desktop
16 Print Manager
17 Network Neighborhood
18 Workgroup
19 Program
20 Document Folder
21 Settings
22 Find
23 Hint
24 Command
25 Screen Saver
26 Docking
27 Display
28 Sharing Overlay (Hand)
29 Shortcut Overlay (Small Arrow)
30 Default Printer Overlay (Small Tick)
31 Recycled Empty
32 Recycled Full
33 Dial-up Networking
34 Desktop
35 Control Panel
36 Program Groups
37 Printers
38 Font
39 Start Menu settings
40 Audio Cd
44 Log Off
45 May not apply to Win98
46 May not apply to Win98
> Hi guys,
> Greatful for help
> All the best
> Mike (n00b)
M
Thanks a lot dot (.) ;-)
I will give it a go and have some smooth icons hopefully
All the best
Mike
<.> skrev i meddelelsen news:OCBGzUcPKHA.1232@newsgroup
> Icons]
> number is the inverse of the resource ID). Omit the comma and Icon Index
> when using an .ICO file.
> then Change Icon, then Browse. Select the file and click open. The icons
> are numbered from 0 downwards then across.
> Value Description
> 0 Unknown File Type
> 1 Default Document
> 3 Folder
> 4 Open Folder
> 5 5.25 inch Floppy
> 6 3.5 inch Floppy
> 7 Removable Drive
> 8 Hard Drive
> 9 Network Drive
> 11 Cd-rom Drive
> 12 Ram Drive
> 13 Globe
> 14 Network Pipes ?
> 15 Desktop
> 16 Print Manager
> 18 Workgroup
> 19 Program
> 20 Document Folder
> 21 Settings
> 22 Find
> 23 Hint
> 24 Command
> 25 Screen Saver
> 26 Docking
> 27 Display
> 31 Recycled Empty
> 32 Recycled Full
> 34 Desktop
> 35 Control Panel
> 36 Program Groups
> 37 Printers
> 38 Font
> 40 Audio Cd
> 44 Log Off
>> Hi guys,
>> Greatful for help
>> All the best
>> Mike (n00b)
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
Hello Mike,
In addition, this is another method to change them as well.
http://www.vistax64.com/tutorials/178915-file-extension-type-icon-change.html
All the best
Mike
> Icons]
> Value Description
> 0 Unknown File Type
> 1 Default Document
> 3 Folder
> 4 Open Folder
> 5 5.25 inch Floppy
> 6 3.5 inch Floppy
> 7 Removable Drive
> 8 Hard Drive
> 9 Network Drive
> 11 Cd-rom Drive
> 12 Ram Drive
> 13 Globe
> 14 Network Pipes ?
> 15 Desktop
> 16 Print Manager
> 18 Workgroup
> 19 Program
> 20 Document Folder
> 21 Settings
> 22 Find
> 23 Hint
> 24 Command
> 25 Screen Saver
> 26 Docking
> 27 Display
> 31 Recycled Empty
> 32 Recycled Full
> 34 Desktop
> 35 Control Panel
> 36 Program Groups
> 37 Printers
> 38 Font
> 40 Audio Cd
> 44 Log Off
>> Hi guys,
>> Greatful for help
>> All the best
>> Mike (n00b)
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
