Change Desktop Icon for custom images
17
Hi there I know where to go to change icons but vista will not allow me to use a custome image.
I am right clicking the desktop > Personalize > then on the left hand side clicking Change Desktop Icons.
But when I browse to my image it does not allow it. I also want to change the default image for folders as well.
Any ideas how I can get around this?
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello Matt,
What type of image are you trying to use to replace the icon with? You will only be able to use 256x256 pixel .ico (icon) files for these. This will give you some more details about icons for Vista if needed.
Vista Icons - Introducing Vista Icons - How to create Vista Icons
To change the default Folder icons, this tutorial will show you how to. You will need to change the DefaultIcon for the Folder key in step 6.
http://www.vistax64.com/tutorials/178915-file-extension-type-icon-change.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Matt,
To change the default icon for all folders, this tutorial will show you how to. You will need to change the DefaultIcon for the Folder key in step 6.
File Extension Type Icon - Change
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
17
Sorry Im being really stupid. Do I need to find the file extension that controls the folders and edit the key to point to the new icon?
If so what is the file extension for a folder?
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#9
I cannot quite make out what it says, but you need to use a .ico file that is a 256x256 pixel icon that is made for Vista. Is this for the DefaultIcon folder under Folders?
If all else fails, you can use the program IconPackager with a 30 day trial period to make the changes you need to the icons. Afterwards, you should be able to uninstall the program and keep the new icon changes.
http://www.stardock.com/products/iconpackager/index.asp
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
17
#10
Is this for the DefaultIcon folder under Folders? = Yes
I will try again.
Is this the tpe of path I should using
C:\Program Files\RocketDock\Leopard PNGs\Leopard Icons (128x128)\Generic Folder.ico
Thanks so far Brink ;-)
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#11
Yes on both, but it should be a 256x256 pixel icon made for Vista (includes all icon sizes in it) for it to display properly in all icon View sizes (small and large).
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
