changing 'documents' location
T
Tim Draper
as a rule of thumb, i move the documents folder to another
partition/drive than the main OS - everytime i reinstall, i dont/cant
loose the documents folder.
i found out how to change location of the documents folder myself (arent
i a big clever boy? :P)
today i move the drive letters around (from 'documents' location on i:\,
to d:\). however, because i've changed drive letters, i cant seem to
find where to change 'documents' location anymore.
i'm SURE it was changeable at C:\Users\USER\, right click 'documents',
and change location. now i've changed drive letters around, the
'documents' shortcut has been deleted by the system.
reason for concern: games.
some games (especially EA games) stores user details/saved games in
'documents' folder. if the system has no reference to 'documents', or
it's pointing incorrectly to i:\documents\, then its not saving the
savegame files to disc
so: is there another location, or a registry edit to fix where
'documents' is pointing to?
thanks
tim
D
You can try opening registry editor and navigate to
HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Explorer/ShellFolders
and change the path in the Personal entry.
HTH
Dale
"Tim Draper" <veehexx_dirtyspam@btopenworld.com> wrote in message
news:OqmdnTLr9rkmavfYnZ2dnUVZ8qKdnZ2d@bt.com...
> thanks
> tim
T
Tim Draper
nail on the head there dale :) thanks
for future knowledge, this surely cant be a common question so how did
you find it?
tim
> HTH
> Dale
>> thanks
>> tim
R
Richard Urban
Go to Start | User name (in right column - usually at the top) You will see
a window with all of your folders.
Right click on a folder and go to properties. There is a tab for "location",
wherever it may be located. Look for the "move" button from here. Follow the
prompts. Doing it this way is the simplest and cleanest way to customize
your setup.
Regards,
Richard Urban
Quote from George Ankner:
If you knew as much as you think you know,
You would realize that you don't know what you thought you knew!
> thanks
> tim
D
The basic functionality has existed since Windows 95. You might look for a
book on registry hacks or search a few registry hack sites. You'll learn
all kinds of cool things to do in the registry that you can't do elsewhere.
Just be sure to backup or export anything you're going to change before you
make the change so you have a way to get back.
Also, in Windows XP and before, there is a GUI you can download for doing
the same thing: search for TweakUI. I imagine that there'll be a Vista
version of TweakUI before too long.
Dale
news:cdOdneuWOckXn_bYRVnygQ@bt.com...
> for future knowledge, this surely cant be a common question so how did you
> find it?
> tim
>> HTH
>> Dale
>>> thanks
>>> tim
D
Great tip! I hadn't seen that before.
Dale
"Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message
news:OXnhRujEHHA.4508@TK2MSFTNGP02.phx.gbl...
> see a window with all of your folders.
> "location", wherever it may be located. Look for the "move" button from
> here. Follow the prompts. Doing it this way is the simplest and cleanest
> way to customize your setup.
> Regards,
> Richard Urban
>> thanks
>> tim
R
Richard Urban
Thanks!
The more we use it, the more we learn, the more we share.
Regards,
Richard Urban
> Regards,
> Richard Urban
>> thanks
>> tim
T
Tim Draper
#8
thats the way i did it in the 1st place (not to sound ungrateful of your
post tho).
vista must of got confused somehow with me removing all drive letters,
and then re-assigning them.
weirdly those options have become available again, so i'm doing it the
clean way as you sugested :)
D
Daze N. Knights
#9
Thanks!!!
Daze
