Changing prompt within a script
G
Garios
If a execute this piece in the PS console then a can change the default prompt:
function prompt {"PS:MyTest: $(get-location)>"}
But if a execute from within a script the new prompt doesn't stick. In other
words I want to be able to change my prompt dinamically as I execute a PS
script to reflect things that I am doing.
I don't want to put this in any profile to load at the beginning only, it
has to be as a execute a script.
Thanks,
L
Larry__Weiss
Try
function global:prompt {"PS:MyTest: $(get-location)>"}
- Larry
> Thanks,
T
Thomas Lee
In message <[email protected]>, Garios
<[email protected]> writes
Correct.
If you run this within a script, it 'sticks' while the script is running
then, since it was defined in the script scope it disappears.
If you have this function definition in f.ps1, then typing:
PSH [C:\foo]> .\f.ps1
results in nothing.
you could try:
PSH [C:\foo]> . .\f.ps1
That's a dot-source of the function.
>In other
Use dot sourcing.
Thomas
Thomas Lee
[email protected]
L
Larry__Weiss
>> default prompt:
> Correct.
> results in nothing.
> you could try:
>> In other
> Use dot sourcing.
> Thomas
In case the script for other reasons is not appropriate for
dot-sourcing,
the global prompt function scope can be accessed via syntax like
Does anyone know how to specify the parent or grandparent scope
for the function name space? I looked and could not find it.
- Larry
