Checking File System on C:
B
My computer ran out of battery and shut down. When I re-started it, it
required a disk check on the C: drive for consistency, it said "Checking file
system on C:The type of the file system is NTFS" It starts to check the
files, but gets to 7 percent complete and pauses every time. There is no way
to cancel the check and no matter how long I leave it there it will never get
past 7 percent. When I try to system restore it says that there is an error
with the C: drive and offers to check the drive at re-start, but then I run
into the same pausing problem.Does anyone know of any solutions to this
problem? I'd really appreciate it!
T
tjb1991
Burr-
If i were you and didnt have any important data i would first try an
Operating System reinstall(that came with your computer or you bought). If
that doesnt work I would concider buying a new hard drive.
R
Rick Rogers
Do you see anything on the hard drive activity indicator light? How long
have you let it pause for? Sometimes the disk checker will make an extensive
pause, and if the drive is large it could be hours to completion. The
percentage of completion shown on the screen is just an estimate, not an
exact measurement.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Burr" <Burr@discussions.microsoft.com> wrote in message
news:5D2682AA-EBA8-4ED3-B28E-CEF004CC4237@microsoft.com...
> file
> way
> get
> error
> run
R
Richard Urban
How large is your C: drive and how much information is on it. I have seen
chkdsk take hours on a 300 gig hard drive that was packed with many small
files.
Regards,
Richard Urban
> file
> way
> get
> error
> run
C
cquirke (MVP Windows shell/user)
On Sun, 1 Jul 2007 10:32:02 -0700, Burr
>past 7 percent.
That's AutoChk / ChkDsk for you... the user control dates from before
MS-DOS 6, even if what they (try to) has been completely revamped.
There are two ways, the "easy" and the "safe"...
The "easy" way is to ignore the possibility that the reason why ChkDsk
(or rather, AutoChk) "stops" like this is because the HD is physically
damaged, or the file system is significantly deranged to the point
that "fixing" it may irreversibly trash data, bootability, or both.
Because these "fixers" are too brain-dead to provide an "escape", you
have to bad-exit via reset or power off when they get "stuck". Hullo,
more file system damage.
Then on next boot, press Esc during the tiny sliver of seconds you
have before AutoChk blunders into action. That gets you into Windows,
which involves all sorts of writes to your at-risk HD and file system.
From there, I'd suggest you backup your data, or what's left of it.
The "safe" way is to make sure the HD is physically OK before rtesting
the file system, and make sure the file system is logically OK before
attempting to boot Windows again.
That means testing the physical HD first, without booting Windows. To
do that, you'd need stuff that you probably didn't get with the PC and
that don't come with Windows, such as the free HD Tune utility from
www.hdtune.com running from a Bart PE boot CDR.
If you have a Vista OS DVD, you can boot that, choose Repair, and find
your way to "Command Prompt". You will have read the at-risk HD's
installation to get this far, and hopefully that won't have bogged
down in file system insanity or bad sector retries.
Now you have successfully booted an off-HD maintenance OS; something
that wasn't possible with XP, if you were a "normal user" and limited
yourself to what MS provides. But you may find that even though you
have HD Tune on a USB stick or CDR, and you can "see" these from the
Vista DVD boot command prompt, they won't run.
There may be other ways to test the physical HD without booting Vista
off it, such as diagnostics from HD vendors, etc. Do what you can, if
there is anything you can find that works.
Else, you'd be forced to take risks, such as trying a ChkDsk /R that
will first "fix" file system errors automatically (no prompting for
permission, no undoability, high risk of data loss) and only then go
on to check the HD surface for errors. This is not much better than
what AutoChk is already failing to do, but at least you have less
Windows writes to the at-risk HD and file system as you go.
I would definitely evacuate that HD before doing anything else, unless
you can test it safely first (e.g. HD Tune off a Bart CDR boot). Even
if testing it first, I'd abandon testing as soon as I saw "just one"
bad cluster, and backup my data, preferably without booting Windows
off the now-known-to-be-failing HD.
Do you get the impression that MS hasn't really thought out this
scenario? I sure do...
The more you write to the disk, the more likely you will lose data and
perhaps bootability, and the less likely you will recover your data.
So System Restore, in these circumstances, is a Bad Idea.
Our senses are our UI to reality
motarola2
Power User
190
-try a "chkdsk /r" and a "fixboot" from the recovery console, you can access it from the recovery CD that came with the computer.
-try to boot the computer and start pressing F8 like crazy, so then you can try to access safe mode, or try last known good configuration. if that doesnt work, reinstall windows.
- if the problem continues then the hard drive is defective.
C
On Wed, 4 Jul 2007 01:51:58 -0500, motarola2
Try to detrmine that before beating it to death with ChkDsk /R ;-)
In fact, I'd back up before doing any diagnostics.
