Checking network connections
H
How can i check the number of incoming network connections in PS. I'm
looking for something similar to net session. ?
Thanks
H
Well i'm creating a backup script (to backup some MS-Access database), but i
want to check if any else in the network is still using the database. So
idea is to check the number of incoming network connections;
"Marco Shaw" <marco.shaw@_NO_SPAM_gmail.com> schreef in bericht
news:Oc0ud3p$HHA.4568@xxxxxx
> Hans wrote:
>> Hi,
>> Thanks
> Did you need anything additional? Because you can just run 'net session'
> directly from within PowerShell.
> Marco
> PowerGadgets MVP
> http://www.powergadgets.com/mvp
> Blog:
> http://marcoshaw.blogspot.com
M
Marco Shaw
> but i want to check if any else in the network is still using the
> database. So idea is to check the number of incoming network connections;
You're best bet might be to check if there's a if there's a lock file
though.
But you can just call 'net session' directly:
PSH> net session
There are no entries in the list.
PSH> $result=net session
PSH> if ($result -like "*no entries*"){"no connections"}
no connections
Marco
O
/\/\o\/\/ [MVP]
gwmi win32_serverSession might give the onfo you need
also you can use performance counters from PowerShell
see also
http://mow001.blogspot.com/2005/12/getting-performancemonitor-info-from.html
h.t.h.
Greetings /\/\o\/\/
> > Hans wrote:
> >> Hi,
> >> Thanks
> > Marco
> > PowerGadgets MVP
> > Blog:
K
On Sep 24, 8:16 pm, "Hans" <hans.hant...@xxxxxx> wrote:
> Hi,
> Thanks
You can use something similar to this:
Get-WmiObject -ComputerName MYSERVER01 -Query {Select * From
Win32_ServerConnection Where NumberOfFiles>"0" and
ShareName="MYSHARE"} | Select-Object UserName,ShareName,NumberOfFiles
| Format-Table -autosize
This will work if the Database is the ONLY thing in the share. For
some reason I can't figure out a way to check specific open files
within shares just connections to a share that have files open.
Replace MYSERVER01 with your server name and MYSHARE with the share
name.
