Chinese Characters not displaying in Chinese Program
A
Andrew
I'm running Vista Business, and installing a program that uses Chinese
characters (Tencent's "QQ").
Although I can read webpages, type in Chinese (in MSN, Word, etc), the
program's interface is supposed to be in Chinese, but instead displays random
symbols, numbers.
The program installs fine on XP with the Chinese language pack, but not on
Vista Business. How can I make the characters display???
Thanks!
C
Chan
Andrew, you can try this, if the programme you installed is a non-unicode
program (if you program is a unicode programe, the character should display
without setting), it works on Windows XP.
Contral panel-->regional and language options-->Advance tab-->set the
"language for non-unicode programs" to a language match with your program
language (in this case chinese).--> restart your computer.
Then run your program, the character should display properly
> symbols, numbers.
> Thanks!
A
Andrew
Hi Chan,
I figured it out just after I posted but forgot to mention the solution.
You're right, this is how to fix it.
Thanks!
Andrew
C
Chinajohn
Hi Chan:
Your info was most helpful. I followed your instructions and everyone is
happy now. It is working great !! Thank you again.
China John D.
> > symbols, numbers.
> > Thanks!
F
furniturehouse
Hi
I got a very similar problem to Andrew except I use Vista home premium,
and my notebook was install in traditional chinese as OS. After i change
the regional setting to chinese(prc), only some of parts of QQ can
display chinese and the buttoms and some words are not display properly.
Is there any way i can fix this problem?
Thanks
furniturehouse
Posted via http://www.vistaheads.com
S
SadOwl
Thank you very much, Chan. I had the same problem. But now, has gone!
Thanks again, Chan!!
> > symbols, numbers.
> > Thanks!
