CHKDSK error: unspecified error occured
20
Location
Yazd
Hello every body.
my pc have a windows vista home premium with 3 derives (C:, D:, F:). from one months ago until now, it starts showing this message to me when i want copy, delete, or install any file on my F: derive: "the disk structure is corrupted and unreadable". i should add that almost every other day it shows this message to me and some times with restarting the pc the problem solves but some days latter again it shows this error.
so i try to do a CHKDSK check at windows startup for my F: derive but at stage 3 it shows this error message: "unspecified error occured".
what should i do?
Thanks
///Ali
    Hp Pavilion
    Intel core 2
    Gforce
    Hp
richc46
Staff member
20,105
Location
Fairfield County, CT
20
Location
Yazd
Thanks, my laptop is hp pavilion, may you describe the solution more?
    Hp Pavilion
    Intel core 2
    Gforce
    Hp
richc46
Staff member
20,105
Location
Those are links that I gave you. Click on them for full instructions.
20
Location
Yazd
Thanks for your advise.
i want add that my laptop manufacturer (HP) add a disk diagnostic to to laptop. when windows is starting i press F10 and then in diagnostic menu, i run hard drive test, it take about 100 min and when finished it reports that there are not any problem with hard drives.
what should i do?
    Hp Pavilion
    Intel core 2
    Gforce
    Hp
richc46
Staff member
20,105
Location
I cannot be familiar with every test out there. I am not familiar with the HP test, though I am pretty sure that your HD is ok. To be completely sure, take the test that I suggest, then we can go to the next step.
20
Location
Yazd
Hello again.
i found that my derives have not any problem and maybe the problem is from corrupted file system.
so if this is true, what should i do?
Thanks.
    Hp Pavilion
    Intel core 2
    Gforce
    Hp
richc46
Staff member
20,105
Location
#8
20
Location
Yazd
#9
thank you so much, my notebook have three drives, c: D: (Vista recovery drive) and F:. My Os installed on C: but I have installed some softwares on F:
my C: and D: do not have any problem, my problem is F:.
how can i run SFC command for F: Not C:?
    Hp Pavilion
    Intel core 2
    Gforce
    Hp
richc46
Staff member
20,105
Location
#10
The SFC only checks the OS or drive c. It wil not check F.
The message that you are getting is not from a corrupted files. If anything it is from the drive itself.
20
Location
Yazd
#11
ok, i do sfc check but SFC cannot fix some files.
i go to cbs.log file and saw so many lines that i cannot understand. how can i fix this problems? and i want to add that i do not have a windows recovery cd but my derive D: is pre-installed windows recovery derive.
    Hp Pavilion
    Intel core 2
    Gforce
    Hp
richc46
Staff member
20,105
Location
#12
If you follow these directions and upload the CBS to us, we have a very talented member who can tell you how to make the corrections manually. The usual way is with the install DVD, which you do not have
Upload CBS File
20
Location
Yazd
#13
OK, i do this:
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log
and here is the result in attachment
    Hp Pavilion
    Intel core 2
    Gforce
    Hp
20
Location
Yazd
#14
also i have another question:
does repairing with this method remove any data from system? does it delet any software or data?
    Hp Pavilion
    Intel core 2
    Gforce
    Hp
richc46
Staff member
20,105
Location
#15
No it only fixes the OS.
But as I said I need help to make the changes that are needed. Ask to be sure about the changes.
It may take time. I will refer this now. The other member may not be online until tomorrow.
20
Location
Yazd
#16
may i ask you when do you will deliver the solution to me?
    Hp Pavilion
    Intel core 2
    Gforce
    Hp
richc46
Staff member
20,105
Location
#17
I have asked for help from someone, who is very talented and conscientious. He will help you as soon as he comes online. I am guessing tomorrow morning.
20
Location
Yazd
#18
Merci, another question: giving this information to another person does have any risk in fields of privacy and security?
    Hp Pavilion
    Intel core 2
    Gforce
    Hp
richc46
Staff member
20,105
Location
#19
We are all members of the forum. Anything that you post can be seen by all the members anyway.
Everything that you have posted so far can be read by anyone in the world that has a computer.
You have given us nothing that can identify you. Just computer stuff.
