Choosing which programs to remove from startup?
I
Itinerantscholar
I bought a Dell Inspiron 1501 with Vista on it. It has the typical
performance problems that have been noted for laptops running Vista. It
receives a "Windows Experience Index" of 2.0.
The first thing you are told to do to improve performance is eliminate
programs from startup. But when I go through the long list of programs, I
often can't tell what they do. For instance, I see in this list "Avantquest
Digital Line Detection," "Dell Quick Set," "Synaptics Pointing Device," and
"Java (TM) Platform SE 6U5," among many others. Do I just start
experimenting and see what happens when I turn them off? That seems very
risky. After all, that "pointing device"--that's my touchpad, isn't it? If
I turned off my touchpad, I think my computer would be useless to me, because
I do not know how to turn the touchpad on again without the touchpad.
In short: is there a way to know which programs would be the best ones to
turn off? In case it is not already obvious, I do not know a lot about
computers. My experience with Vista has been frustrating, because I feel
like I do not have the specialized technical training required to make my
laptop work well.
R
Robert Hankins
Begin by downloading a nifty little program www.winpatrol.com
This will help you to identify quickly which programs you don't need as for
instance: You don't need media players until you actually have a need.
Disable Windows Media Player, Real player or Dell Player. If you don't
dabble in photos regularly, disable Roxio, Windows Photo or Picasa if
loaded. If you don't play games,then disable all the games.
Take your time, go slow (THINK) and keep notes about what you have changed.
Remember that setting up a new computer in Vista might take a couple of
weeks until you get everything organized the way you want it.
C
"Itinerantscholar" <Itinerantscholar@xxxxxx> wrote in
message news:CDD65D7B-6B32-4024-9B33-5D6B772ABEEE@xxxxxx
> "Avantquest
> and
> If
> because
> laptop work well.
If you want to know what an item is or what it does you can type the
item into a searchbar and discover its purpose.
If you don't need access to a program at startup you can disable it.
You can then go to your All Programs list at any time and activate it when
it is needed.
C.B.
It is the responsibility and duty of everyone to help the underprivileged
and unfortunate among us.
M
Mike Hall - MVP
> "Avantquest
> and
> If
> because
> laptop work well.
Which of the five elements gets you a base score of '2'?
Bear in mind that laptops have to balance between sheer power and battery
life. You could change the power settings, but ensure that you are connected
to the mains power.
How much memory do you have installed? You need more than 1gb RAM because
the video card will take maybe 256mb, leaving you with less than optimum for
everything else..
Mike Hall - MVP
How to construct a good post..
http://dts-l.com/goodpost.htm
How to use the Microsoft Product Support Newsgroups..
http://support.microsoft.com/default.aspx?pr=newswhelp&style=toc
Mike's Window - My Blog..
http://msmvps.com/blogs/mikehall/default.aspx
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
laptop work well.
Hello,
This link will let you know what the listed startup programs are for with recommendations if they are safe or not.
CastleCops® - StartupList
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
