Choppy Playback of Burned DVD
M
MSUTech
Hello All,
I have a lot of home movies that, through IEEE 1394, I put on our home
laptop. PREVIOUSLY I was able to select the setting of 2.1 mbps, for the
speed of the movie.
When I burn those 2.1 mbps movies to DVD, from Windows Vista, the dvds look
great.
NOW, in Windows Vista, I don't seem to have an option of what speed I want
to save these movies at, when I am transferring them from my video camera,
through IEEE 1394 - I think it defaults to 4 mbps.
MY PROBLEM: If I create a dvd from these new 4 mbps videos, that dvd is very
choppy and really hard to watch. I tried to use movie maker to drop it to 3
mbps, then create another dvd, but, the movie is still choppy.
Can someone help me determine the best way to take my home movies, from my
camera, and get them to DVD, without being so choppy?
thanks,
A
Adam Albright
On Tue, 24 Jul 2007 07:36:13 -0700, MSUTech
<MSUTech@discussions.microsoft.com> wrote:
>Hello All,
>speed of the movie.
>great.
>thanks,
Just for your information Mbps has nothing to do with speed, it is the
overall QUALITY at which the video is encoded at. The higher the
bitrate the better the quality, however don't get tricked into
assuming you can take a low bitrate source file and make it "better"
just by re encoding at a higher bitrate. That don't work.
Speed for videos is determined by the frame rate which is how many
frames happen per second of playback. For North America, Japan, a few
other countries (see map) the expected frame rate for DVD's is 29.970
frames a second which is based on NTSC specs.
http://en.wikipedia.org/wiki/NTSC
For the rest of the world it is PAL specs.
As far as your question choppy playback can be caused from several
things. The slower the bitrate the easier it is for the decoder. If
you try to play back a high bitrate video on a under powered PC your
computer may have trouble keeping up, thus choppy playback. How does
the DVD play on a set top DVD player?
You can also get choppy results if the source file is encoded at a low
frame rate. For example if you download some video off the web that
was made on a Web Cam, often they use very low frame rates of 12
frames or less per second. The trouble here is it doesn't matter what
the bitrate is, that just sets the quality and has zero impact on
frame rate. If that's the problem the solution is to increase the
frame rate.
Need more information. Brand, model of camera, what frame rate and
bitrate your source files are, are you using Movie Maker exclusively
or something else, things like that.
<CLIP>Just for your information Mbps has nothing to do with speed</CLIP>
But, It has everything to do with the DVD players ability to play back
smoothly or choppy.
Lowering the bitrate will decrease the quality, but will increase
compatibility with standalone DVD players. I burn and distribute 100's of
homemade DVD's and everytime I burn higher than 4Mbs, I get complaints from
people about choppy playback.
you have to determine what tradeoff you are willing to make to get a nice
quality DVD that most players can play.
"Adam Albright" <AA@ABC.net> wrote in message
news:647ca39kibchqn27vmfuopfc75vsudrbpj@4ax.com...
>>Hello All,
>>speed of the movie.
>>look
>>great.
>>very
>>3
>>thanks,
> frame rate.
A
Adam Albright
On Thu, 26 Jul 2007 16:54:07 -0600, "KDE"
>smoothly or choppy.
The suggested floor for DVDs is 6000 Mbps for a constant bitrate, can
be way lower if you use a variable bitrate. If you use 4000 Mbps or
less the quality isn't close to DVD specs.
If a DVD player can't handle 6000 Mbps then there is something wrong
with the DVD player or more likely the player has trouble with the
brand of DVD media you're using or the format. You're using + or - ?
Typically the problem most amateurs make is using too a high a
bitrate, over 8000 Mbps that for sure will freak out a lot of DVD
players and cause them to play back jerky or choppy.
L
I have a similar problem!
see "Frame rate quality loss using Windows Vista Ulitmate Movie Mak" thread.
Hope we can resolve this before I spend a couple of hundred dollars just to
get the same prblem on the next software availabel!
> >smoothly or choppy.
A
Adam Albright
On Sat, 28 Jul 2007 03:22:06 -0700, Leon
Editing videos on a computer and making DVDs can be a complex task and
there are many pitfalls. I've got plenty of bumps and bruises to prove
it ;-)
As I've said before I'm using Vista Business which Microsoft didn't
see fit to include DVD Maker in. So I'm in the dark how good or bad it
performs. What I can tell you is at the heart of making good videos
that play as expected when making DVDs is the encoder. MPEG-2 encoders
which is the source file type DVDs MUST be encoded to prior to doing
the final DVD burning phase aren't free. They are licensed software.
Which one Microsoft includes if you have the Home Premium or Ultimate
version that include DVD Maker I have no idea. Some MPEG-2 encoders
are simply better, some WAY BETTER than others. I doubt Microsoft
includes a really good one.
Lets look deeper. An explanation of a few terms; GOP (Group of
Pictures) and the three types of frames that make up a video,
respectively called "I", "P" and "B" frames.
As most people already know a video is nothing more than a long series
of still images (frames) played back at a fast enough rate that tricks
the human eye into seeing motion. Under NTSC specs, a compliant MPEG-2
video has a frame rate of 29.970 frames per second. That's fast enough
to get smooth motion.
A GOP starts with an "I" frame, sometimes referred to as a key frame
usually followed by a number of "P" and "B" frames. Each GOP is
analyzed separately. GOPs can be just a single "I" frame or many
frames combined.
In "I" frames Spatial Compression removes redundancies within a single
frame of video. The encoder or the compressor a more accurate term
looks at each "I" frame separately regardless of the frames preceding
or following it. The frame is divided into blocks, which are then
transformed using discrete cosine transformation and get compressed at
about a 7:1 ratio.
With "P" frames which stands for Predicted Frames, these follow
I-Frames. A "P" frame's content and/or color has changed from the
preceding I-Frame. However since "P" frames only contains data that
has changed, they can't be displayed on their own needing a preceding
"I" frame to fill in the sequence's original content.
Trying to avoid getting too technical, "B" frames are bi-directional
predicted frames that remove more redundancies by looking at changes
in frame content or color based on both previous and subsequent frames
which require "I" frames surrounding by "P" frames. So a typical one
second of MPEG-2 video would like something like this:
A GOP: I BB P BB P BB P BB P BB I BB P BB P BB P BB P BB
Ok, why should you care? How well the MPEG-2 encoder does this dance
the better the quality of the resulting video.
Another factor is bitrate. If you encode at a constant bitrate you
don't get efficient compression and in effect only increase file bloat
with no increase in video quality.
Generally "I" frames get compressed about 7:1, while "P" and "B"
frames can often get easily compressed at 20:1, even higher without
objectionable loss of quality.
So, (finally) we answer the question. Why do videos play choppy? If
the more common reasons already offered in another reply earlier
aren't to blame, then suspect the encoder.
Here's why: If nothing much is changing frame to frame then little if
any prediction is happening, so the encoder isn't guessing what it can
safely drop as redundancies in preceding frames. However if the action
in the video starts to get fast and heavy then the bitrate better be
high enough to handle it. If it isn't then the encoder is forced to
make more predictions and the quality of "P" and "B" frames will go
way down since the encoder isn't making good decisions and may drops
needed detail, hence choppy playback can be the result because your
eyes are starting to detect noticeable changes frame to frame.
So the bottom line is better encoders do a better job of encoding and
not only can you control the dance better, but you control what
bitrate and even can use two pass encoding and other things. Again, I
don't have Microsoft's DVD Maker so I don't know if it is capable of
offering good control or changes in what bitrate you get to use or
not.
L
That all sounds OK.... but, why is the quality all 100% if I do not edit the
video and encode the complete 1hr and burn to DVD?
The problem only occurs when I use Windows Moviemaker to edit. The project
is saved as a .MSWMM file.
So I think the frame rate is lost between the Moviemaker and the DVD Maker,
and that the DVD Maker is OK, as it does encode good quality unedited videos.
Any ideas?
> it ;-)
> frames combined.
> about a 7:1 ratio.
> not.
J
John Lee Brown
#8
What antivirus software are you running. I have discovered that it can
easily interfere with video editing so I shut it off during editing, also
while the computer is doing the edit you cannot do anything else.
"Leon" <Leon@discussions.microsoft.com> wrote in message
news:99A0CE20-C53E-4220-913C-AA935FC1C858@microsoft.com...
> the
> Maker,
> videos.
> Any ideas?
>> >thread.
>> >to
>> it ;-)
>> frames combined.
>> about a 7:1 ratio.
>> not.
L
#9
I use McAfee.
I do not run any other applications while the DVD is encoded. I have a Intel
Dual Core 6600 (2x2.4GHz) pc with 2GB RAM. So I think that should be enough :)
What I do not understand that in one instance it is working great, but not
if I edited the movie.
> > the
> > Maker,
> > videos.
> > Any ideas?
> >> >thread.
> >> >to
> >> it ;-)
> >> frames combined.
> >> about a 7:1 ratio.
> >> not.
J
John Lee Brown
#10
When you edit you are converting the video but when you are going straight
to DVD you are not always converting the video. It is during that conversion
that choppiness and video/voice out of sync happen.
news:4A8C8645-0674-4345-899B-CEEDAAD0557C@microsoft.com...
> Hi,
> I use McAfee.
> Intel
> enough :)
>> > edit
>> > the
>> > project
>> > Maker,
>> > videos.
>> > Any ideas?
>> >> >thread.
>> >> >just
>> >> >to
>> >> it ;-)
>> >> frames combined.
>> >> about a 7:1 ratio.
>> >> not.
L
#11
So do you then suggest I dump this Microsoft stuff that came with Vista
Ultimate and purchase something that keep the quality after editing?
Can you recommend any desent editing software?
> > Hi,
> > I use McAfee.
> > Intel
> > enough :)
> >> > edit
> >> > the
> >> > project
> >> > Maker,
> >> > videos.
> >> > Any ideas?
> >> >> >thread.
> >> >> >just
> >> >> >to
> >> >> it ;-)
> >> >> frames combined.
> >> >> about a 7:1 ratio.
> >> >> not.
J
John Lee Brown
#12
I use Ulead's Movie Factory but there are a lot of other programs out there
that others like better.
news:4C4E41BF-4FBF-4840-A326-8540D119F5E1@microsoft.com...
>> straight
>> conversion
>> > Hi,
>> > I use McAfee.
>> > Intel
>> > enough :)
>> > not
>> >> also
>> >> > edit
>> >> > the
>> >> > project
>> >> > Maker,
>> >> > unedited
>> >> > videos.
>> >> > Any ideas?
>> >> >> >Mak"
>> >> >> >thread.
>> >> >> >dollars
>> >> >> >just
>> >> >> >to
>> >> >> and
>> >> >> prove
>> >> >> it ;-)
>> >> >> it
>> >> >> encoders
>> >> >> doing
>> >> >> software.
>> >> >> Ultimate
>> >> >> series
>> >> >> tricks
>> >> >> MPEG-2
>> >> >> enough
>> >> >> frame
>> >> >> frames combined.
>> >> >> single
>> >> >> preceding
>> >> >> at
>> >> >> about a 7:1 ratio.
>> >> >> preceding
>> >> >> bi-directional
>> >> >> changes
>> >> >> frames
>> >> >> one
>> >> >> dance
>> >> >> bloat
>> >> >> if
>> >> >> can
>> >> >> action
>> >> >> be
>> >> >> drops
>> >> >> and
>> >> >> I
>> >> >> of
>> >> >> not.
