Cisco VPN Client 4.8.02.0010
J
J. Wilder
I just downloaded the latest Cisco VPN Client for Vista 4.8.02.0010. I had to
install several times until I stopped getting errors. Then when it finally
installed without error, when I tried to use it I get an error "Reason 440:
Driver Failure"
Has anyone tried this version yet? If so do you know a workaround for it?
C
Carey Frisch [MVP]
Right-click on the downloaded file and select "Run as Administrator".
Carey Frisch
Microsoft MVP
Windows Shell/User
Driver Failure"
R
Rick Rogers
Did you install as administrator or just run from an administrator account?
The latter does not set the proper permissions for a lot of software. To
properly install, right click the installer file and use 'run as
administrator'.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"J. Wilder" <JWilder@discussions.microsoft.com> wrote in message
news:143B3C5E-66DC-4D37-BED5-56D05D6EEE9E@microsoft.com...
>to
> 440:
> Driver Failure"
J
J. Wilder
i still get the same errors, I think this may be a Cisco problem. Thanks for
your help!
"Rick Rogers" wrote:
> Hi,
> administrator'.
> Best of Luck,
> >to
> > 440:
> > Driver Failure"
J
J. Wilder
I removed the client, then ran setup with the "Run as Administrator". I still
get the same errors. I think this is a Cisco problem. Thanks for your help.
> Carey Frisch
> Microsoft MVP
> Windows Shell/User
> Driver Failure"
B
BurningSpleen
Get it @ http://www.bu.edu/nsg/vpn/ms/testmsvpn.htm -it works!
> Driver Failure"
