Class implementation help please
B
billymyersiii
I am having trouble determining how to get this to work if possible. I
need to have different class instances write html to a single class
instance that creates one InternetExplorer.Application Window and has
a method that captures all data from the other classes.
Expected result is: 1 window will popup and display the text from all
method calls th addhtml
Dim cls1, cls2
Set cls1 = New TestClass
Set cls2 = New TestClass
cls1.addhtml("<b>test1</b>")
cls2.addhtml("<b>test2</b>")
Class TestClass
End Class
Class TestClass
addhtml("<b>test3</b>")
End Class
Class TestClass
addhtml("<b>test4</b>")
End Class
Class TestIE
Private oIE
Public Function addhtml(html)
If NOT (oIE is Nothing) Then
Set oIE = CreateObject
("InternetExplorer.Application")
oIE.visible=1
End If
oIE.document.write html
End Function
End Class
A
Alex K. Angelopoulos
<billymyersiii@xxxxxx> wrote in message
news:45f970d8-7a5b-46fe-a529-ea866c004cc2@xxxxxx
> Dim cls1, cls2
> Class TestClass
> End Class
> Class TestClass
> End Class
> Class TestClass
> End Class
> Class TestIE
> Private oIE
> oIE.visible=1
> End If
> End Function
> End Class
Option Explicit
Class IeWriter
Dim MyIE
MyIE.document.write html
End Function
End Class
Dim cls1, cls2, globalIE
' You want a single IE instance to be used by multiple class
' instances. To make it work, you need to create the IE instance
' in one location and ensure that apps using it have a ref
' to the same instance.
' One way that works is this.
' First, create a global IE object
Set globalIE = CreateObject("InternetExplorer.Application")
' navigate, wait, then make it visible.
globalIE.Navigate "about:blank"
do while globalIE.ReadyState <> 4: WScript.Sleep 20: Loop
globalIE.Visible = true
' Now create an instance of our IeWriter class:
Set cls1 = New IeWriter
' The IeWriter has a public MyIE property that we can fill with
' our global IE instance:
Set cls1.MyIE = globalIE
'Now repeat for another instance of the IeWriter class:
Set cls2 = New IeWriter
Set cls2.MyIE = globalIE
cls1.addhtml "<b>test1</b>"
cls2.addhtml "<b>test2</b>"
B
billymyersiii
I'm sorry, I currently have it working this way, but looking for a way
to let the class(s) handle the implementation not the calling code. It
makes no sense to implement this code every time if it is a
requirement across all classes. That is why I am trying to move it out
of the calling code and into the class code. It seems that everytime I
try to do so I end up with multiple IE windows if you know what I
mean.
On Jun 5, 4:07 pm, "Alex K. Angelopoulos" <alex(dot) k(dot again)
angelopoulos(at)gmail.com> wrote:
> <billymyers...@xxxxxx> wrote in message
> > Dim cls1, cls2
> > Class TestClass
> > End Class
> > Class TestClass
> > End Class
> > Class TestClass
> > End Class
> > Class TestIE
> >          Private oIE
> >                           oIE.visible=1
> >                   End If
> >          End Function
> > End Class
> Option Explicit
> Class IeWriter
>           Dim MyIE
>           End Function
> End Class
> cls2.addhtml "<b>test2</b>"- Hide quoted text -
> - Show quoted text -
