Closing programs
T
Tyrone
With windows xp you only needed to ctrl-alt-del to view running programs and
close them, before installing new software. How do you close programs for xp?
Tyrone
Brink
Staff member
mvp
That doesnt neccessarily show all running programs, unless you are also
refering to 'running processes'
Simply close those that show in your task bar, generally by rt clicking on
them to bring up the context menu
"Tyrone" <Tyrone@xxxxxx> wrote in message
news:181B7E11-C66B-4DA3-BFE3-A352FBF2F4AB@xxxxxx
> and
> xp?
> Tyrone
T
Tyrone
Yes, I meant "XP", and thanks!, very much!!
Tyrone
"Brink" wrote:
> > and
> > for xp?
> > Tyrone
> Hi Tyrone,
> Did you mean in Vista?
> If so, you can press Ctrl+Shift+Esc to open Task Manager to close
> non-responding programs. You can see more on this in this tutorial if
> needed.
> http://www.vistax64.com/tutorials/121580-task-manager-open-close-applications-processes.html
> Hope this helps,
> Shawn
> Brink
> *There are no dumb questions, just the people that do not ask
> them.*
> '*VISTA FORUMS*' (http://www.vistax64.com)
> *Please post feedback to help others.*
T
Tyrone
Thanks, DL!!
Tyrone
> > and
> > xp?
> > Tyrone
Brink
Staff member
mvp
Tyrone
> Hi Tyrone,
> needed.
> Hope this helps,
> Shawn
> Brink
> them.*
Your welcome Tyrone. Did these posts help fix your problem?
