Comdlg32.ocx
bodybreak
I've been trying to register Comdlg32.ocx on my new system... quite the exercise in frustration! For a while, it wouldn't find the file, but I think I have worked around that problem by giving permissions to all users, since you can't Run As Admin for an .ocx file.
However, I'm geting a new error now:
The module "comdlg32.ocx" may not be compatible with the version of Windows that you're running. Check to see if the module is compatible with an x86 (32-bit) or x64 (64-bit) version of regsvr32.ocx.
My system is a 64-bit, so I'm pretty sure I would need the 64-bit comdlg32.ocx module. Does such a thing exist? Where can I find it? There are lots of sites out her with downloads for this module, but none seem to specify 32-bit or 64-bit.
Thanks!
P
Peter Foldes
See the following
http://windowsxp.mvps.org/comdlg32.htm
regsvr32 <ocx/dll filename>
to register, and
regsvr32 /U <ocx/dll filename>
to unregister
Peter
Please Reply to Newsgroup for the benefit of others
Requests for assistance by email can not and will not be acknowledged.
"bodybreak" <[email protected]> wrote in message news:[email protected]
> Thanks!
> bodybreak
M
Mr. Arnold
"Peter Foldes" <[email protected]> wrote in message
news:e%232mbg%[email protected]
See the following
to register, and
to unregister
Did you not read the OP's post? It seems to me that he has already tired
what you are suggesting, and he cannot do it. It flat-out told him that he
cannot register the comdlg32.ocx on the machine, which is a 32 bit solution
he is trying to reegister on a 64 bit machine.
> Thanks!
> bodybreak
bodybreak
Hi Peter,
Yes, that is the command I have been trying since I bought my machine, but it is not working. I either get the error from my original message, or this one:
The module "C:\Windows\system32\comdlg32.ocx" failed to load. Make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependent .DLL files. The specified module could not be found.
M
Mr. Arnold
> Hi Peter,
> or this one:
> could not be found.
Most likely, comdlg32.ocx is dependant upon some other DLL(s) that are not
on the 64 bit platform that are on the 32 bit platform.
P
Peter Foldes
And which is the same(comdlg32.ocx ) on a 64bit and if the OP will check in his system file he should see it as such.
As an example Same as before Win98 was 32 bit and was running 16 bit from previous systems as does XP among others
Just do a search for a 64 bit of this file for example on Google
Peter
"Mr. Arnold" <MR. [email protected]> wrote in message news:[email protected]
> See the following
> to register, and
> to unregister
> news:f6fc90b4d46ba913cc652b709cc[email protected]
>> Thanks!
>> bodybreak
M
Mr. Arnold
There is no 64 bit version of comdlg32.ocx. It's a 32 bit COM solution.
You can still register the ocx. For Vista Ultimate x64, you need to place
the Comdlg32.ocx in the \Windows\SysWOW64\ dir. you can then run "regsvr32
C:\Windows\SysWOW64\Comdlg32.ocx" and it will register the file.
The \Windows\System32\ dir is for 64 bit dlls only.
http://en.wikipedia.org/wiki/WOW64
http://msdn.microsoft.com/en-us/library/aa384249(VS.85).aspx
P
Peter Foldes
The reason you cannot find a 64 bit of this ocx is because there is none to be found. It is only comdlg32.ocx which you should replae as per the instructions from Ramesh on his page which is the link that I have included in my previous post.
Here it is again
Peter
> Thanks Peter. I'm having trouble digging up a 64 bit version of this
> module. Can you find one for me??
> bodybreak
M
Mr. Arnold
Here it is again
The link doesn't address what needs to be done on the 64bit platform with a
32 bit COM program.
