comparing a string that contains a parenthesis
C
Caliman
Hi, I'm having trouble finding documentation on this.
For example, if a string value is "Intel(R) Pentium(R) 4 CPU 2.00GHz",
using -match " 4 CPU 2.00" gives True, but
using -match ") 4 CPU 2.00" gives False, and
using -match "`) 4 CPU 2.00" gives False, and
using -match ') 4 CPU 2.00' gives False.
How do you compare a string if it contains a parenthesis?
Thx.
K
Kiron
-match uses regular expression. RegEx special char must be escaped with a
backward slash '\'.
$str = 'Intel(R) Pentium(R) 4 CPU 2.00GHz'
$str -match '\) 4 CPU 2.00'
# these are the RegEx special chars that need to scape
Kiron
C
Caliman
Thanks, Kiron. That works for me. So, when do I use the backtick character
'`' to escape a character?
> backward slash '\'.
> Kiron
K
Kiron
The backtick '`' is used to escape PowerShell special chareacters in
double-quoted strings. It's also used to prevent a variable from expanding in
a doubke-quoted string. Also, the backtick is used to indicate line
continuation
You can read about this:
get-help about_escape_character
get-help about_special_characters
Kiron
S
Shay Levy [MVP]
Hi Caliman,
You can also use the escape() static method to do the magic for you, it is
very usefull when you dont know the string content in advance (like with
variables content):
PS > [regex]::escape(") 4 CPU 2.00")
\)\ 4\ CPU\ 2\.00
PS > "Intel(R) Pentium(R) 4 CPU 2.00GHz" -match [regex]::escape(") 4 CPU
2.00")
True
Shay Levy
Windows PowerShell MVP
http://blogs.microsoft.co.il/blogs/ScriptFanatic
PowerShell Toolbar: http://tinyurl.com/PSToolbar
C> Thanks, Kiron. That works for me. So, when do I use the backtick
C> character '`' to escape a character?
C>
C> "Kiron" wrote:
C>
>> with a backward slash '\'.
>> # these are the RegEx special chars that need to scape # . $ ^ { [ (
>> -- Kiron
J
Josh Einstein
Sounds like what you want in this case is the -like operator.
'Hello World' -like 'Hello *'
True
Josh Einstein
"Caliman" <[email protected]> wrote in message
news:[email protected]
> Thx.
