Comparing folder ACL's
C
Cory Smith
I'm writting a powershell script to drill through our file shares to
determine exactly where an ACL changes from parent to child. It seems
to work for the most part, however, I've just discovered one problem.
The relevent part of the code is here:
$acl = Get-Acl $folder | select *
$pacl = Get-Acl $folder.psparentpath | select *
if ($acl.accesstostring -eq $pacl.accesstostring){...
The problem is that, occasionally, the ACL's will actually be the same
but ordered differently. For example:
Parent_Folder
Builtin\Administrators FullControl
Builtin\Users Read
Child_Folder
Builtin\Users Read
So, while the ACL is technically the same, the script sees these two
variables as being different...
Any idea's on how to do this differently?
R
Rob Campbell
How about:
$acl = (Get-Acl $folder).access | sort
$pacl = (Get-Acl $folder.psparentpath).access | sort
$diff = compar-object $acl $pacl
$diff
> Parent_Folder
> Builtin\Users Read
> Child_Folder
> Builtin\Users Read
V
Vadims Podans [MVP]
just to correct mistake: should be Compare-Object.
WBR, Vadims Podans
MVP: PowerShell
PowerShell blog - www.sysadmins.lv
"Rob Campbell" <[email protected]> rakstÄ«ja ziņojumÄ
"news:[email protected]"...
> How about:
> $diff
>> Parent_Folder
>> Builtin\Users Read
>> Child_Folder
>> Builtin\Users Read
sticky27
Try this:
Code:
Function Compare-ACL {
    [cmdletbinding()]
    Param (
        [parameter(mandatory=$True)][String]$ReferenceObject,
        [parameter(mandatory=$True)][String]$DifferenceObject
    $ReferenceObjectACL = ((Get-ACL $ReferenceObject).AccessToString).Split("`n")
    $DifferenceObjectACL = ((Get-ACL $DifferenceObject).AccessToString).Split("`n")
    Compare-Object -ReferenceObject $ReferenceObjectACL -DifferenceObject $DifferenceObjectACL
