Compressed (zipped) folders error
R
Ralph
I've recently bought a new computer and upgraded to Vista. I have numerous
files backed up and encrypted with password protection. WHen I try to open
these files I get the Compressed (zipped) folders error and a message that
WIndows cannot complete the extraction - destination file could not be
created. Also extraction error 0x80004005: unspecified error appears. How
can I open these files?
fld562
R
Ronnie Vernon MVP
Ralph
If you used the EFS file encryption and did not perform a backup of the
encryption certificates, you may not be able to recover those files.
Best practices for the Encrypting File System:
http://support.microsoft.com/kb/223316
The following software purports to be able to recover encrypted files.
'ELCOMSOFT: Advanced EFS Data Recovery'
http://www.elcomsoft.com/aefsdr.html
Ronnie Vernon
Microsoft MVP
Windows Shell/User
"Ralph" <Ralph@xxxxxx> wrote in message
news:26C9AA07-B106-4D0B-9F85-5BCA6F05B854@xxxxxx
> numerous
> open
> How
> fld562
J
Joseph Dignam
Had the same issue.
Found a resolution for it for use.
Looked in the users C:\Temp and found that if a user has extracted 99 files from a zip folder it will not extract a 100th. User simply gets an error.
Removed all files like the following Temp99_Compressed files.zip from the users C:\Temp folder and they were able to extract the information from a zipped folder.
This was in Vista x86, assume it may be the same in other versions.
Hope this helps
Joseph
13-Dec-07
fld562
Previous Posts In This Thread:
On Thursday, December 13, 2007 3:05 PM
fld562
Submitted via EggHeadCafe - Software Developer Portal of Choice
WPF Datagrid as ComboBox Dropdown Part 2
http://www.eggheadcafe.com/tutorial...96-e24127040bbf/wpf-datagrid-as-combobox.aspx
