Computer connects to 'Unidentified' network
My PC runs Windows Vista and I am on an ADSL plan (for broadband internet).
I turn my modem on and off before and after each internet session for
security reasons. Recently, my computer seems to connect to two networks -
"Public network" (which is the internet gateway) and another "unidentified"
network. I don't know how this network came about and this seems to preclude
me from using the internet. I am being forced to disable my networks and
re-enable them again, after which only the Public Network re-appears. Then, I
am able to use the internet as per normal. Is there a way of getting rid of
this "unidentified" network? so that I can connect to the intenet seamlessly,
as I was able to do before?
Your help in this regard is much appreciated.
Thanks.
R
Robert L. \(MS-MVP\)
Do you have two NICs? Post the result of ipconfig /all may help.
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"ZP" <ZP@xxxxxx> wrote in message
news:F3AEEB42-E49C-4289-9148-3A43002B9686@xxxxxx
> Hi,
> internet).
> "unidentified"
> preclude
> Then, I
> of
> seamlessly,
> Thanks.
This appears to bw a common problem.
I had a similar problem which turned out to be caused by an update to
Comodo Firewall Pro.
When I un installed the firewall the problem disappeared.
I do not know what the firewall was doing to stop the network
connecting with the DHCP in the router.
DJT
On Sun, 20 Apr 2008 20:48:00 -0700, ZP <ZP@xxxxxx>
wrote:
>Hi,
>Thanks.
Thanks for your reply. I just have one NIC. Don't know how or why the
"Unidentified Network" came about.
> > Hi,
> > internet).
> > "unidentified"
> > preclude
> > Then, I
> > of
> > seamlessly,
> > Thanks.
R
This search result may help.
news:8C03D673-D720-40CB-ADDC-72B5B54A4CD5@xxxxxx
>> > Hi,
>> > internet).
>> > networks -
>> > "unidentified"
>> > preclude
>> > and
>> > Then, I
>> > rid
>> > of
>> > seamlessly,
>> > Thanks.
