Computer Shuts Down but Fan Keeps Running
E
E.Lucius
I am using Windows Vista and although Vista will shut down when I click
Start->Shut Down (Vista closes and the monitor goes dark), but my fan
continues to run idefidintely. Any ideas on how to resolve the issue?
S
Stubby
"E.Lucius" <[email protected]> wrote in message
news:[email protected]
Maybe your CPU or the box itself is over temperature. Or you may have a
BIOS setting that keeps the fan on. Note that there is a power supply
that is always on so the start-button logic works. My guess is the fan is
running off of that rather than the normal +5 vdc supply.
Brink
Staff member
mvp
Hi E.Lucius,
Check to make sure that you have your Power Plan Options set correctly for the sleep mode that you are using in Step Two of this tutorial.
http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
Also check to make sure that you BIOS is set to the S3 Sleep state in Step Three of the same tutorial.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
