Connecting to All Users Desktop
J
Hi
I have below code to change the icons of all shortcuts on All User Desktop.
Problem is I am connecting to All Users' Desktop twice, once using Namespace
and second using SpecialFolders. Is there a way to simplify code to connect
to All Users Desktop only once?
Sorry if it is dumb. I am very new to vbscript.
Many Thanks
Regards
Set oFS = CreateObject("Scripting.FileSystemObject")
Set objShell = CreateObject("WScript.Shell")
Const ALL_USERS_DESKTOP = &H19&
Set objShellApp = CreateObject("Shell.Application")
Set objFolder = objShellApp.Namespace(ALL_USERS_DESKTOP)
strFolder = objShell.SpecialFolders("AllUsersDesktop")
For Each objFile In oFS.GetFolder(strFolder).Files
If Right(LCase(objFile.Name), 4) = LCase(".lnk") Or
Right(LCase(objFile.Name), 4) = LCase(".url") Then
Set objFolderItem = objFolder.ParseName(objFile.Name)
Set oLink = objFolderItem.GetLink
oLink.SetIconLocation "C:\Windows\System32\SHELL32.dll", 109
oLink.Save
End If
Next
A
Alex K. Angelopoulos
John,
Actually, you're not really doing extra work per se, but if I understand you
correctly, you want to make the code look cleaner somehow. It's still
easiest to find the items by iterating through with the filesystemobject I
believe, but you can get the path directly from the shell.application
object, like this:
strFolder = objFolder.Self.path
As for dumb - you should see some of the things _I_ asked when I was first
starting out. You know the drill - the only dumb question is the one you
didn't ask. : )
"John" <info@xxxxxx> wrote in message
news:O7JvH9xoJHA.3840@xxxxxx
> Hi
> Desktop. Problem is I am connecting to All Users' Desktop twice, once
> using Namespace and second using SpecialFolders. Is there a way to
> simplify code to connect to All Users Desktop only once?
> Many Thanks
> Regards
> oLink.Save
> End If
> Next
