Connecting to wireless network - EAP properties return error
J
Jitse
Good day,
I'm trying to connect to the wireless network of my university, but I keep
getting the same error. I did everything correct, but when I want to apply
the certificate to the connection, I get an error.
What I do is this: I go the the network centre, choose "Manage Wireless
Networks". Then I right-click the wireless network, and choose properties.
Then I go to the "Security" tab. When you look at the "method of network
verification" listbox, "Protected EAP (PEAP)" is chosen (which is correct).
Next to the listbox I click "Configuration..." (so I can select the correct
certificate). But I simply get an error when I press that configuration
button.
This is the error:
Windows has encountered an error saving the EAP properties. Specific
error: The specified module could not be found.
Maybe my description is a little vague, here's a clear screenshot:
http://www.geocities.com/xargotheone/offsite/error.jpg
Thanks in advance. :)
M
Mick Murphy
http://www.microsoft.com/technet/community/columns/cableguy/cg0406.mspx
The above link is for wireless networking.
I think you are complicating it!!!
"Jitse" wrote:
> Good day,
> button.
> This is the error:
J
Jitse
I'm certainly not. I did exactly what's written in that article you've given
me. Except from one thing, because it's simply not possible because I get
that error. It's at this point:
(image of the article)
http://img.microsoft.com/library/media/1033/technet/images/community/columns/cableguy/cg040606.gif
(my own screenshot)
I've got as options:
Security Type: 802.1x
Encryption Type: WEP
Network Authentication Method: Protected EAP (PEAP)
All I have to do now, is click that "Settings..." button and select the
correct certificate. But when I click that button I get that error (as you
can see in my own screenshot or read in the starting post of this topic).
Could anyone help me with this please?
J
Jeffrey Randow
Try using TLS if you are doing Cert Based 8021x...
Jeffrey Randow
jeffreycentex@xxxxxx
Windows Networking MVP 2001-2006
http://www.networkblog.net
On Thu, 18 Oct 2007 09:01:01 -0700, Jitse
>(my own screenshot)
J
Jitse
Do you mean the "SecureW2 TTLS"? I tried that, then I get about the same error:
error: Unspecified error.
> Jeffrey Randow
> >(my own screenshot)
J
Jitse
Alright nevermind, I found the problem. It's this stupid SecureW2 third-party
program that's supposed to help you with setting up a wireless connection,
hehehe. It was even recommended by the technical notes of the server I wanted
to connect to. It's probably just a Vista 64bit incompatibility.
Thanks for the replies though. :)
I
ivo.a.l.vieira
Can you tell me what you have done to fix it?
I have exacly the same problem that you had. I'm a student of IST, I
have Vista Ultimate 64bit and I also need SecureW2.
Please help me.
Greetings
Ivo Vieira
