Connects to router, but not to internet (I have tried EVERYTHING! help!)
wiseguy
Ok guys, to start things off I recently moved so I had to change from using a wired connection to a wireless connection. I bought a Netgear Wireless - N Router (WNR2000) and a Wireless-N 300 USB adapter. I'm running vista home premium x64 SP2.
Everytime I diagnose the problem, it gives me the "there may be a problem with your DNS configuration" or the "cannot communicate with primary dns server". I have tried everything of my power, and I have called my ISP and router company. Both were useless. I have tried manually setting my dns servers but it didn't work, and usually gives me the "cannot communicate.... primary server" junk. I would be very grateful if you guys could help. Here is my ipconfig :
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Keiths-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection 5:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : RangeMax Wireless-N USB Adapter WN111v
Physical Address. . . . . . . . . : 00-26-F2-A5-F5-70
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Sunday, May 09, 2010 10:23:38 PM
Lease Expires . . . . . . . . . . : Monday, May 10, 2010 10:23:38 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : USB Wireless 802.11 b/g Adaptor
Physical Address. . . . . . . . . : 00-22-5F-75-3A-3E
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : NVIDIA nForce 10/100 Mbps Ethernet
Physical Address. . . . . . . . . : 00-21-97-CA-B9-E1
I'm gonna post the ipconfig on the computer with the modem just in case it's necessary.
ok here it is :
C:\Documents and Settings\john>ipconfig/all
Host Name . . . . . . . . . . . . : jimmy-6509eb19b
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : Yes
Description . . . . . . . . . . . : Motorola SURFboard SB5100 USB Cable
Modem
Physical Address. . . . . . . . . : 00-0E-5C-75-22-B1
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 67.86.181.190
Subnet Mask . . . . . . . . . . . : 255.255.240.0
Default Gateway . . . . . . . . . : 67.86.176.1
DHCP Server . . . . . . . . . . . : 10.240.178.41
DNS Servers . . . . . . . . . . . : 167.206.251.129
167.206.251.130
Lease Obtained. . . . . . . . . . : Sunday, May 09, 2010 9:10:44 PM
Lease Expires . . . . . . . . . . : Tuesday, May 11, 2010 9:10:44 PM
Ethernet adapter Local Area Connection 3:
Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated Controller
Physical Address. . . . . . . . . : 00-18-8B-59-FC-58
IP Address. . . . . . . . . . . . : 192.168.1.2
Lease Obtained. . . . . . . . . . : Sunday, May 09, 2010 10:53:49 PM
Lease Expires . . . . . . . . . . : Monday, May 10, 2010 10:53:49 PM
thanks again
M
Michael W Ryder
Re: Connects to router, but not to internet (I have tried EVERYTHING!help!)
> WN111v
I think your problem is here. Normally the DNS servers will be
addresses given to you by your IP and will NOT be your router. You
might be able to use the old address especially if you are with the same
provider.
> Ethernet
> *_I'm_gonna_post_the_ipconfig_on_the_computer_with_the_modem_just_in_case_it's_necessary_*.
> ok here it is :
> USB Cable
> Modem
> 167.206.251.130
> PM
> 9:10:44 PM
> DNS Servers . . . . . . . . . . : 192.168.1.1
> 10:53:49 PM
> 10:53:49 PM
> thanks again
wiseguy
ok, I've got it solved. Someone on another message board helped me. Here is his instructions:
Humm: Let's see if we can get this working with an ethernet connection.
Tips on setting up broadband connection, courtesy of Johnwill
You don't need any setup disk to configure a broadband router.
Reset the router to factory defaults by holding the reset button down for 15 seconds with power on. The following procedure should get you a connection with any broadband modem that is configured to use DHCP for the router connection, such as cable modems, and many DSL modems. If you require PPPoE configuration for the DSL modem, that will have to be configured to match the ISP requirements.
• Turn off everything, the modem, router, computer.
• Connect the modem to the router's WAN/Internet port.
• Connect the computer to one of the router's LAN/Network ports.
• Turn on the modem, wait for a steady connect light.
• Turn on the router, wait for two minutes.
• Boot the computer.
When the computer is completely booted, let's see this.
Hold the Windows key and press R, then type CMD (COMMAND for W98/WME) to open a command prompt:
NOTE: For the items below in red surrounded with < >, see comments below for the actual information content, they are value substitutions from the previous command output!
In the command prompt window that opens, type type the following commands one at a time, followed by the Enter key:
IPCONFIG /ALL
PING <computer_IP_address>
PING <default_gateway_address>
PING <dns_servers>
PING 206.190.60.37
PING yahoo.com
Right click in the command window and choose Select All, then hit Enter to copy the contents to the clipboard.
Paste the results in a message here.
It looks to me from your ipconfigs that Jimmy is working hard plugged to the modem and Keith is wired up to the router,but the logical connection between the router and modem have not been made.Looks like maybe a plugging issue,but let's see if Keith can get a working ethernet connection first.
Night Hawk
Welcome to the VistaForums! wiseguy
The instructions you saw are close to what the ISP used here provided for adding on a router(hardwired/WiFI too) inline with the cable modem. You first have to shut everything off and patch the router in having used Cat #6 ethernet cables here.
When first replugging the ac adapter in for the modem here and firing that up it re-established the ISP's IP address. Then you plug in or turn the power for router on to see that create a new private IP and act as if it was your pc.
Once that is seen to and you start your system up you may need to go into the Control Panel>Network section and work on the home group or setting it to home network if the connection isn't immediate.
    Custom built desktops =2 Toshiba replace HP laptop
    AMD Phenom II X4 975 Deneb core 3.6ghz
    Gigabyte GA-790XTA-UD4
    Kingston Hyper X 1.5v DDR3 PC12800 1600mhz 16gb
    MSI Radeon HD 5750 1tb
    Creative X-Fi XtremeAudio PCIe
    Asus 19" HP 20" second lcd main HP 20" remote pc.
    1440x900, 1600x900 main - 1600x900 2nd desktop
    WD Black Edition 1tb Sata II -2
    WD SAS "Heavy Duty" RE class 2tb - 2
    External usb/eSata WD Black 1tb main -1
    External usb only WD Green Power 1tb -1
    Corsair 750w 750TX main - Corsair 600w remote
    Antec 900-2 - SSD compatible eSata ports 2 - NZXT Vulcan 2nd
    Zalman CNPS9900A cpu, twin front 120s, top 200cm, rear 120
    MSI Interceptor D200
    AZIO Ilumminated keys gaming keyboard/volume control usb
    30mbps upgrade
