G
Guy
I was noticing odd disconnects running networked application on my laptop
since installing vista on it. After quite a bit of delving, what I'm seeing
is this.
I'm using ping as a way of checking for network connectiveity, it is a basic
but seemingly effective way of seeing how well I'm connected.
When I test my connection by pinging a known machine from vista I get a
pretty consistent 6-12% packet loss as reported by ping. It doesn't seem to
matter whether I use a wireless card or the builtin wired network card on the
laptop. Changing the cable doesn't change this result. Another machine on
the same cable gets 0% loss (it's running xp). Rebooting back to xp on the
original laptop gets 0% packet loss.
As far as I can tell, this is affecting two different network cards so I'm
hard pressed to think that it's a network card driver issue, but I've got no
clue how to pin this down. Right now my only solution is to switch back to
xp where this hardware suddenly works perfectly.
Any suggestions as to how I track this down?
BTW the machine is up to date as far as windowsupdate is concerned.
Thanks - Guy
is this.
Thanks - Guy
