Control Panel Is Blank
S
Spike
When I try getting into my control panal its completly blank other times it
doesn't show up @ all
Spike
Thanks for sharing.
Is your spell checker not working? How about your punctuation keys? Are they
malfunctioning as well?
"Spike" <Spike@xxxxxx> wrote in message
news:FA3F4D25-ACE8-49B2-BE20-0B9DFCD089C8@xxxxxx
> it
> Spike
S
Spike
No only my control panal. Almost acts as if its been completely deleted out
of the system. I can access some programs that are in the control panal from
my start menu but others I can't find at all that were in the cotrol panal
Spike
"Bob" wrote:
> Thanks for sharing.
> > it
> > Spike
B
BurrWalnut
If some items are missing go to the Windows Orb (Start), type regedit, press
Enter and navigate to registry key HKEY_CURRENT_USER\Control Panel\don’tload
and delete items in the right pane that you want to see in Control Panel.
If Control Panel is not appearing at all go to the Windows Orb (Start), type
regedit, press Enter and navigate to registry key
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer.
In the right pane look for NoControlPanel, right-click it and make its value
0 (zero).
If you are denied entry to regedit it’s a classic symptom of infection.
> Spike
