Controling Line-in/Aux/Tad-in from Volume Control Dialog
M
Marcus Kern
I'm using a TV Card that requires Card To card Sound connection. so I plug it
into my Aux-in on my sound card on the inside of my computer.
Is there a way instead of going four clicks deep to adjust the sound?
is there a way to put the input sound controls on the volume Controls Dialog?
I've read and seen alot about the Per-app Control but when it comes to a
constant non-app controled input... what can we do? go four clicks deep then
ajust the sound? I'd rather just click a check box to always have the Aux-in
Slider show up on the Volume control dialog.
I love the rewrite of the whole sound control. it's just, a bit more
tinkering to make it convienant. :)
Marcus
Sky
