Convert Active Directory IADSLargeInteger
J
Jobbsy
I thought this was going to be easy after finally getting my hands on the AD
User
pwdlastset values - I am now unable to convert them - I have tried
using the System.DirectoryServices.DirectorySearcher method described in the
following url
http://bsonposh.com/modules/wordpress/?p=30
but am unable to get past the first hurdle no matter what i try I receive
the following
error:
+ param([string]$LdapPath,[string]$Attribute = $(throw <<<< "Attribute
Required"),[string]$server,[switch]$date)
any help would be much appreciated as yet again i have spent far too much
time trying to overcome this - I have done the conversion before no problem
in VBScript - again I am reluctant to install Quest cmdlets as they are
labelled as 'RC' and this script will (if I ever finish it!) be running on
Prod DCs
I have also used tried the following with no success:
http://weblogs.asp.net/adweigert/ar...rectory-iadslargeinteger-to-system-int64.aspx
jobbsy@xxxxxx
B
Brandon Shell [MVP]
It is not a string. What are you using $attribute for?
Hello Jobbsy,
> the AD
> User
> in the
> following url
> receive the following error:
> "Attribute Required"),[string]$server,[switch]$date)
> much time trying to overcome this - I have done the conversion before
> no problem in VBScript - again I am reluctant to install Quest cmdlets
> as they are labelled as 'RC' and this script will (if I ever finish
> it!) be running on Prod DCs
> http://weblogs.asp.net/adweigert/archive/2007/03/23/powershell-convert
> -active-directory-iadslargeinteger-to-system-int64.aspx
G
Gaurhoth
Using adweigert's ConvertADSLargeInteger should work just fine. I use it
all of the time. Here's an example of it's usage:
PS D:\ps> $user = [ADSI]"LDAP://cn=Peter
Petrelli,cn=users,dc=testlab,dc=com"
PS D:\ps> [datetime]::FromFileTimeUtc((ConvertADSLargeInteger
$user.pwdlastset.value))
Saturday, October 27, 2007 8:17:30 PM
If there is something else you are having a problem with, post more of
the function or script and maybe we can troubleshoot it.
Gaurhoth
> User
> following url
> the following
> error:
> Prod DCs
B
Brandon Shell [MVP]
I dont think converting the value is the problem... it looks like using the
As I ask before... what do you use $attribute for?
Hello Gaurhoth,
> it all of the time. Here's an example of it's usage:
> Gaurhoth
>> the AD
>> User
>> in the
>> following url
>> cmdlets as they are labelled as 'RC' and this script will (if I ever
>> finish it!) be running on Prod DCs
>> t-active-directory-iadslargeinteger-to-system-int64.aspx
J
Jobbsy
Thanks Gaurhoth - what I needed was an example of it's use, however I still
am unable to see it working successfully, so excuse me for my ignorance if
there is an elementary mistake as i am a beginner but this is the code I am
trying to use it in, and like before with adweigert's ConvertADSLargeInteger
after seeing your example and trying to fit it to my code I still receive
exactly the same error as before - below the error is a sample of my code:
Exception calling "InvokeMember" with "5" argument(s): "Method
'System.Int64.HighPart' not found."
At 45 char:56
+ $highPart = $adsLargeInteger.GetType().InvokeMember( <<<< "HighPart",
[System.Reflection.BindingFlags]::GetProper
ty, $null, $adsLargeInteger, $null)
'System.Int64.LowPart' not found."
###########Sample############
foreach ($person in $adobj)
$prop=$person.psbase.properties
$i++
$1stField = "$($prop.name)" + ","
$2ndField = "$($prop.memberof)" + ","
$3rdField = "$($prop.whencreated)" + ","
#$4th Field - Password Last Set
#Convert the large Integer format into a readable date
$LI = [datetime]::FromFileTimeUtc((ConvertADSLargeInteger
$($prop.pwdlastset)))
$4thField = "$LI" + ","
$strOutputString = "$1stField" + "$2ndField" + "$3rdField" + "$4thField"
jobbsy@xxxxxx
> Gaurhoth
> > User
> > following url
> > the following
> > error:
> > Prod DCs
B
Brandon Shell [MVP]
Your having problems parsing the date? You will notice you should should
use Parse not fromfiletimeUTC
I have a -date parameter on my Get-iADSLargeIntFromSearcher function
function Get-iADSLargeIntFromSearcher{
param([string]$LdapPath,[string]$attribute = $(throw "Attribute Required"),[string]$server,[switch]$date)
if($server){$de = [ADSI]"LDAP://$server/$LdapPath"}
else{$de = [ADSI]"LDAP://$LdapPath"}
$return = new-object system.DirectoryServices.DirectorySearcher($de)
$value = ($return.findone()).properties[$attribute.ToLower()]
if( $date)
[datetime]::FromFileTime([int64]::Parse($value))
else
$value
# This should put the Date in $LI
$LI = Get-iADSLargeIntFromSearcher $prop.distinguishName "pwdLastSet" -date
Hello Jobbsy,
> still am unable to see it working successfully, so excuse me for my
> ignorance if there is an elementary mistake as i am a beginner but
> this is the code I am trying to use it in, and like before with
> adweigert's ConvertADSLargeInteger after seeing your example and
> trying to fit it to my code I still receive exactly the same error as
> At 45 char:56
> "HighPart",
> $i++
> #---------------------------------------------------------- #Convert
> "$4thField"
>> of the function or script and maybe we can troubleshoot it.
>> Gaurhoth
>>> on the AD
>>> User
>>> described in the
>>> following url
>>> before no problem in VBScript - again I am reluctant to install
>>> Quest cmdlets as they are labelled as 'RC' and this script will (if
>>> I ever finish it!) be running on Prod DCs
>>> rt-active-directory-iadslargeinteger-to-system-int64.aspx
J
Jobbsy
Thanks Brandon but I think I'm going to need a little more spoon feeding on
this one:
Exception calling "FindOne" with "0" argument(s): "Unknown error (0x80005000)"
At C:\PS1Scripts\ActiveDirectory.ps1:65 char:30
+ $value = ($return.findone( <<<< )).properties[$attribute.ToLower()]
Exception calling "Parse" with "1" argument(s): "Input string was not in a
correct format."
At 68 char:48
+ [datetime]::FromFileTime([int64]::Parse( <<<< $value))
jobbsy@xxxxxx
> if( $date)
> else
> $value
> Hello Jobbsy,
> > At 45 char:56
> > "HighPart",
> > $i++
> > "$4thField"
> >> Gaurhoth
> >>> on the AD
> >>> User
> >>> described in the
> >>> following url
J
Jobbsy
#9
This is only a single DC Test Domain and I am running the script on the DC -
the account I am logged on as is a member of Enterprise Admins
jobbsy@xxxxxx
> "Unknown error (0x80005000)" implies access denied. Do you have permission
> in the AD?
> Hello Jobbsy,
J
Jobbsy
#10
Gaurhoth - thanks for your response - I'm still struggling I'm afraid I
wondered if you could help some more?
Here is how I'm trying to fit it to my code:
$i++
$LI = [datetime]::FromFileTimeUtc(ConvertADSLargeInteger $($prop.pwdlastset))
$4thField = $LI
Reccuring Error for each $person:
At 46 char:56
+ $lowPart = $adsLargeInteger.GetType().InvokeMember( <<<< "LowPart",
[System.Reflection.BindingFlags]::GetProperty, $null, $adsLargeInteger, $null)
Exception calling "Copy" with "5" argument(s): "Source array was not long
enough. Check srcIndex and length, and the array's lower bounds."
At 50 char:25
+ [System.Array]::Copy( <<<< $bytes, 0, $tmp, 4, 4)
Exception calling "ToUInt32" with "2" argument(s): "Destination array is not
long enough to copy all the items in the collection. Check array index and
length."
At 54 char:47
+ $lowPart = [System.BitConverter]::ToUInt32( <<<< $bytes, 0)
jobbsy@xxxxxx
> Gaurhoth
> > User
> > following url
> > the following
> > error:
> > Prod DCs
