Convert from vbScript to Powershell
O
OldDog
Here is a fragment of a vbScript that I have:
XL.Range("B2").Select
XL.Selection.FormatConditions.Delete
XL.Selection.FormatConditions.Add xlExpression,, "=COUNTIF(A:A,A2)>1"
XL.Selection.FormatConditions(1).Interior.ColorIndex = 42
XL.Selection.Copy
XL.Columns("B:B").Select
XL.Range("B2").Activate
XL.Selection.PasteSpecial xlPasteFormats, xlNone, False, False
Basically what it does is change to interior color of a cell if the
statement is true.
I tried this:
for($i = 2; $i -le 13; $i++)
If ($ws1.Cells.Item($i,2) -eq "=COUNTIF(A:A,A2)>1") {
$ws1.Cells.Item($i,2).Interior.ColorIndex = 8;
$ws1.Cells.Item($i,2).Font.ColorIndex = 0;
$ws1.Cells.Item($i, 2).Font.Bold = $true;
But that colors every cell blue. I also tried:
If ($ws1.Cells.Item($i,2) -eq "TRUE")
And $true with no luck.
Any ideas?
OldDog
W
Wolfgang Kais
Hi OldDog.
"OldDog" write:
> Hi,
> XL.Selection.Copy
> statement is true.
> I tried this:
> Any ideas?
Your code does not at all look like the vbscript. How about this:
$XL.Range("B2").Select() | Out-Null
$XL.Selection.FormatConditions.Delete()
$XL.Selection.FormatConditions.Add(2, 0, "=COUNTIF(A:A,A2)>1") | Out-Null
$XL.Selection.FormatConditions.Item(1).Interior.ColorIndex = 42
$XL.Selection.Copy() | Out-Null
$XL.Columns.Item("B:B").Select() | Out-Null
$XL.Range("B2").Activate() | Out-Null
$XL.Selection.PasteSpecial(-4122, -4142, $false, $false) | Out-Null
Regards,
Wolfgang
O
OldDog
On May 23, 4:04 pm, "Wolfgang Kais" <[email protected]> wrote:
> Hi OldDog.
> "OldDog" write:
> > XL.Selection.Copy
> > statement is true.
> > I tried this:
> > Any ideas?
> Regards,
> Wolfgang- Hide quoted text -
> - Show quoted text -
Your method works very well, Thank you!
BTW, do you know how to do a two column sort?
I tried this:
$xlSortValues = $xlPinYin = 1
$xlAscending = 1
$xlDescending = 2
$xlYes = 1
$range1 = $ws1.Range("A2:E$lastrow")
$range2 = $ws1.Range("B2:B$lastrow")
$range3 = $ws1.Range("E2:E$lastrow")
[void]$range1.sort($range2, $xlDescending , $range3,$nul,
$xlAscending)
But it does not sort the second column.
W
Wolfgang Kais
Hello OldDog.
"OldDog" wrote:
> Do you know how to do a two column sort?
> I tried this:
> $xlAscending = 1
> $xlDescending = 2
> $xlYes = 1
> $xlAscending)
Only specify the first cell to be sorted (not tested):
$range2 = $ws1.Range("B2")
$range3 = $ws1.Range("E2")
This was not a conversion problem, was it?
Regards,
Wolfgang
O
OldDog
On May 23, 11:57 pm, "Wolfgang Kais" <[email protected]> wrote:
> Hello OldDog.
> > I tried this:
> > $xlAscending = 1
> > $xlDescending = 2
> > $xlYes = 1
> > $xlAscending)
> Regards,
Yes it is, although I have been trying to figure this one out for a
long time.
I tried it as you sugested and I get an error:
Exception calling "Sort" with "5" argument(s): "Reference is not
valid."
At E:\Scripts\PS1\XLFindDups.ps1:133 char:19
+ [void]$range1.sort <<<< ($range2,$xlDescending,$range3,$xlPinYin,
$xlAscending
+ CategoryInfo : NotSpecified: (:) [],
MethodInvocationException
+ FullyQualifiedErrorId : ComMethodTargetInvocation
Here is my code:
$xlAscending = 1
$xlDescending = 2
# one-column sort --> works
#[void]$range1.sort($range2,$xlDescending)
[void]$range1.sort($range2,$xlDescending,$range3,$xlPinYin,
$xlAscending)
# If I put $nul in place of the $xlPinYin, I don't get an error but
the second column does not sort.
# Here is the macro from Excel:
# ActiveWorkbook.Worksheets("FindDups").Sort.SortFields.Add
Key:=Range("B2:B9") '
# , SortOn:=xlSortOnValues, Order:=xlDescending,
DataOption:=xlSortNormal
Key:=Range("E2:E9") '
# , SortOn:=xlSortOnValues, Order:=xlAscending,
# And here is the vbScript I am trying to convert:
# XL.Range("A:E").Sort xl.Range("B2"),2,xl.Range("A2"),,
1,xl.Range("C2"),1,1,1,False,,1
Thanks for looking at this.
OldDog
O
OldDog
> > Hello OldDog.
> > > I tried this:
> > > $xlAscending = 1
> > > $xlDescending = 2
> > > $xlYes = 1
> > > $xlAscending)
> > Regards,
> long time.
> valid."
> $xlAscending
> Here is my code:
> $xlAscending = 1
> $xlDescending = 2
> $xlAscending)
> OldDog- Hide quoted text -
I found this on the Scripting guys web site:
$r = $ws1.UsedRange
$r2 = $ws1.Range("B2")
$r3 = $ws1.Range("E2")
$r4 = $ws1.Range("C2")
$a = $r.Sort($r2,$xlDescending,$r3,$null,$xlAscending, `
$r4,$xlAscending,$xlYes)
Seems that the "$a = $r.sort" is the Key item I was missing.
