Converting 64 bit Vista to 32 bit
MUDDUX
1
this is something I would possibly like to undertake. I purchased Native Instrument Komplete 6 and that is not compatible with 64 bit Vista.
I would very much like to use the software. I was wondering if there was a way to convert my system. one thing that is stopping me is the audio interface i am running I am using the beta driver provided by Presonus.
At either rate, please tell me if there is a way to accomplish this.
Thanks
Chris
3,375
The only way to convert 64bit Vista to 32bit Vista is to do a clean install, losing all your programs and settings. I will think about and come back to you on whether it is possible to get Native Instrument Komplete 6 to work under 64bit. BTW, Vista 64bit and Vista 32bit require different install CDs and different lisence codes.
EDIT Have you looked at the KB Native Instruments, as I cannot access it.
Sorry,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
richc46
Staff member
20,105
Location
Fairfield County, CT
A license is good for 32 or 64 bit platforms. The CD's are different. As a rule, if you buy a particular edition (Vista HP, for example), you will receive on key number and 2 DVD. You can change back and forth between 32 and 64 as many times as you like. But on only one computer at a time.
If you have a valid key, you can probably get the DVD from Microsoft for shipping cost plus a small mark up.
