converting CSV comma to csv semi-column
T
Teddy
HI !
I am trying to convert a csv file with comma to a csv file with
semi-column.
I tried import-csv, export-csv, convert from...
It didn't work. I don't understand. I'm an idiot !
What would be the best way ?
can you help me please?
thanks
M
Marco Shaw [MVP]
You can only do this with PowerShell v2:
PS>import-csv input.csv|export-csv -delim ";" output.csv
PowerShell v1 doesn't support the -Delimiter parameter.
Marco
"Teddy" <noreply@newsgroup> wrote in message
news:4be52db9$0$15666$426a74cc@newsgroup
> HI !
> semi-column.
> thanks
T
Teddy
"Marco Shaw [MVP]" <marco.shaw@newsgroup_SPAMgmail.com> a écrit dans le message de
news:uX4K%23vp7KHA.5808@newsgroup
> Marco
thank you Marco, but it doesn't work too.
Import-Csv: Can not process argument, the argument value "name" is not
valid. Change the value of the argument "name" and rerun the operation. At
line: 1 Character: 11
+ import-csv <<<< input.csv|export-csv -delim ";" output.csv
+ CategoryInfo : InvalidArgument: (:) [Import-Csv],
PSArgumentExc
eption
+ FullyQualifiedErrorId :
Argument,Microsoft.PowerShell.Commands.ImportCsv
Command
where input.csv is real file I rename from excel csv one
I run powershell 2 under W7
L
Larry__Weiss
On 5/8/2010 9:20 AM, Teddy wrote:
> "Marco Shaw [MVP]"
> At line: 1 Character: 11
> + CategoryInfo : InvalidArgument: (:) [Import-Csv], PSArgumentExc
> eption
> + FullyQualifiedErrorId : Argument,Microsoft.PowerShell.Commands.ImportCsv
> Command
Reading from
http://softwareblog.morlok.net/2009/04/17/powershell-import-csv-error/
I learn that the error you are getting is related to the content
of your file input.csv
Be sure that input.csv is a valid CSV formatted file.
That article states that even Excel can produce a CSV file that
causes this error.
- Larry
T
Teddy
> Reading from
> causes this error.
> - Larry
thank you Larry, I think it's right but ...
I tried with an other file, now input.csv only contain :
test1,test2,test3,test4
when I run import-csv input.csv|export-csv -delim ";" output.csv
there is no more error, but output file is empty !!!
I am desapointed !
It's the 1st time I use powershell.
I tried :
PS C:\temp> $data = get-content input.csv
PS C:\temp> $p
PS C:\temp> $data
so input.csv is ok
L
Larry__Weiss
On 5/8/2010 10:08 AM, Teddy wrote:
>> Reading from
>> causes this error.
> I am desapointed !
> I tried :
> PS C:\temp> $p
> PS C:\temp> $data
> so input.csv is ok
For the simplest CSV files it turns out to be more complicated.
You have to provide column header captions via a parameter.
And, if you wish to create a simple CSV as output you have to do
some post-processing.
With import.csv containing
Try these PowerShell commands
import-csv -header "col1","col2","col3","col4" input.csv |
export-csv -delimiter ';' output.csv
$a = (get-content output.csv)
$a[2..($a.count - 1)] | out-file -encoding ASCII output.csv
- Larry
T
Teddy
"Larry__Weiss" <lfw@newsgroup> a écrit dans le message de
news:%23K$%236Vt7KHA.420@newsgroup
>>> Reading from
>>> causes this error.
>> I am desapointed !
>> I tried :
>> PS C:\temp> $p
>> PS C:\temp> $data
>> so input.csv is ok
> - Larry
thank you Larry, your PowerShell commands works well !!
Now, I should have to see what it is wrong with my real file exported by
excel. it doesn't work no more.
L
Larry__Weiss
#8
On 5/8/2010 1:09 PM, Teddy wrote:
> "Larry__Weiss"
suggests it is usually some trailing (right-most) extraneous data.
- Larry
T
Teddy
#9
news:u7Egatt7KHA.720@newsgroup
>> "Larry__Weiss"
> - Larry
thank you, I'll take a look.
Teddy
T
Teddy
#10
>> "Larry__Weiss"
> - Larry
Hi Larry
you are right !
The error I got is related to the empty value between commas !
no way to change this because the file is generate automaticaly with a
sofware under visual basic !
I tried to change "," to ";"
with Foreach{$_.Replace(",", ";")}
but when there is a value like "125,10" the result is "125;10"
in France, "," is the separate for decimal instead of point so we write
125,10 instead of 125.10
thank you
Teddy
H
Hans Dingemans
#11
Not sure this has to do with the initial question, but note that Export-CSV
and Import-CSV also have a -UseCulture parameter
PS> get-culture
LCID Name DisplayName
1043 nl-NL Dutch (Netherlands)
PS> (Get-Culture).TextInfo.ListSeparator
PS>
Get-Process | Export-Csv c:\processes.csv; Invoke-Item c:\processes.csv
#provided Excel is present
Above pipe results in a spreadsheet with comma-separated strings in Column
A. Probably not what you want.
Get-Process | Export-Csv c:\processes.csv -UseCulture; Invoke-Item
c:\processes.csv # note the new 2.0 UseCulture parameter
This is the sheet you want, with columns for ALL process properties; not
just the eight columns you know in PS console.
From the (2.0) help file:
-UseCulture
Use the list separator for the current culture as the item delimiter. The
default is a comma (,).
This parameter is very useful in scripts that are being distributed to users
worldwide. To find the list separator for a culture, use the following
command: (Get-Culture).TextInfo.ListSeparator.
Type info above the heading can be suppressed by -NoTypeInformation
parameter.
HtH,
Hans
"Teddy" <noreply@newsgroup> schreef in bericht
> HI !
> semi-column.
> thanks
