Converting the sine of an angle to degrees, minutes, and seconds
J
JungleJim74
I am using VS2003 Professional and am trying to display the other two angles
of a right triangle in degrees, minutes, and seconds. This is easy enough to
do with my desktop calculator but I am having difficulty doing it in DOTNET
code. I find the sine of an angle as .6157548327167 which is the sine of an
angle a little over 38 degrees. How do I get this to 38 degrees ? minutes ?
seconds? Thanks in advance for any help and have a good day.
JungleJim74
H
Hans Kesting
It happens that JungleJim74 formulated :
To go from the sine of an angle to it's value, use the Math.Asin()
method. This will return a value in radians. Note: there is also a
Math.Acos() method that starts with the cosine.
There are "pi" radians in 180 degrees, so you will have to divide the
answer by Math.PI and multiply by 180.
There is no built-in method that displays this number in degress,
minutes and seconds so you will have to calculate that yourself.
The Math.Truncate() method could help here.
For more methods, see
http://msdn.microsoft.com/en-us/library/system.math.aspx
Hans Kesting
A
Andrew Morton
Andrew Morton wrote:
> Use Math.Asin to get the angle in radians and then use google to find
> the conversion.
> http://www.freevbcode.com/ShowCode.asp?ID=8179
Or if you were using a later version of VS, you could do the conversion like
Dim a As Double = Math.Asin(0.06316308504476903) * 180.0 / Math.PI
Dim d As Double = Math.Truncate(a)
Dim t As New TimeSpan(CLng((a - d) * 36000000000.0))
Console.WriteLine("{0} {1} {2}", d, t.Minutes, t.Seconds) ' ->3 37 17
Watch out for negative angles.
Andrew
J
JungleJim74
Re: Converting the sine of an angle to degrees, minutes, and secon
Thank you so much but when I try to use the Function that is shown when I
click on your link I get an error in my compiler
C:\MyDotNet\DecimalDegreesToDMS\Form1.vb(197): 'Truncate' is not a member of
'System.Math'.
"How do I eliminate this compiler error? TIA
JungleJim74
> > the conversion.
> Andrew
F
Family Tree Mike
> 'System.Math'.
What version of VS are you using?
Mike
A
Andrew Morton
> of
> 'System.Math'.
Oh! Math.Truncate appears to not be in .NET 1.1.
Did you know you can get a free version of Visual Basic 2008 Express?
http://www.microsoft.com/express/vb/Default.aspx
Otherwise, you can define
Function truncate(ByVal x As Double) As Integer
If Math.Sign(x) >= 0 Then
Return Math.Floor(x)
Else
Return Math.Ceiling(x)
End If
End Function
HTH
Andrew
