Copy-Item Recurse with Wildcard
A
Aquinas
Can you use Copy-Item recursively with a wildcard? Something like:
Copy-Item c:\folder\*.txt c:\folder2 -Recurse
That's just one of many variations of this. None worked. Using the wildcard
is important. I _can_ get a recursive copy to work without wildcards. It
should also preserve the folder structure.
O
/\\/\\o\\/\\/ [MVP]
works for me (and i'm used to working like this now in PoSH ),
dir -recurse c:\powershell *.ps1 | copy -destination c:\test -whatif
still should work IMHO (at least second example (using provider function)
but do only one level :
copy c:\powershell\* c:\test -include *.ps1 -rec -whatif
copy c:\powershell\* c:\test -filter *.ps1 -rec -whatif
guess directories are excluded also then (makes some sence in object terms
(directory being just another object, but the filter is provide specific )
still as -filter is provider specific should be able to this while in the
filesystem provider i would think.
thoughts ?
greetings /\/\o\/\/
"Aquinas" <[email protected]> wrote in message
news:[email protected]
> wildcard
K
Keith Hill [MVP]
"/\/\o\/\/ [MVP]" <[email protected]> wrote in message
But that doesn't preserver the directory structure of where the ps1 file was
located relative to C:\powershell.
Keith
A
Aquinas
I'd like to know if it can be done with only the Copy-Item command, and I'd
like it to preserve the directory structure. To reiterate, I'm looking to use
Copy-Item recursively with a wildcard while preserving the directory
structure.
The Powershell help doesn't say you can't but doesn't say you can either.
Although I think it's implied that it can, or at least I get the impression
that it should be doable. After all, it lists -Recurse and -Container as
parameter options.
It seems odd that I had to end up going to cmd.exe to do a Copy /s to get it
done.
> thoughts ?
> greetings /\/\o\/\/
> > wildcard
T
Tom G.
Maybe the following will do what you're trying to achieve. On my
machine, this copied all text files in all subdirectories of C:\source
and copied them to C:\Dest while preserving the folder structure.
copy-item -rec -filter *.txt C:\Source C:\Dest
Tom G.
> and I'd like it to preserve the directory structure. To reiterate,
> I'm looking to use Copy-Item recursively with a wildcard while
> preserving the directory structure.
> either. Although I think it's implied that it can, or at least I get
> the impression that it should be doable. After all, it lists -Recurse
> and -Container as parameter options.
> get it done.
> > function) but do only one level :
> > object terms (directory being just another object, but the filter
> > is provide specific ) still as -filter is provider specific should
> > be able to this while in the filesystem provider i would think.
> > thoughts ?
> > greetings /\/\o\/\/
> > > the wildcard
> > > is important. I can get a recursive copy to work without
> > > wildcards. It should also preserve the folder structure.
A
Aquinas
Yes, that did it! It's the filter option. I guess I was fixated on the
-include option, after all, that's what I use when I use get-childitem
recursively.
thanks.
> Tom G.
> > get it done.
> > > thoughts ?
> > > greetings /\/\o\/\/
> > > > the wildcard
