Copying ZIPped Files Across Network Doesn't Work
J
Jay Somerset
Does any body else have a problem transferring files to/from a
wireless-connected Vista system and a LAN-connected Vista machine? I
do -- the transfers frequently hang up and drop the wireless
connection until I manually abort the transfer.
It never happened between wireless Vista and cable-connected Win2K --
only if both systems are Vista, and there are multiple, embedded .zip
files. It seems as though Vista just can't handle the
unzipping/zipping without timing out somewhere.
Has anyone else seen this, and has anyone found a solution?
Jay (remove dashes for legal email address)
J
Jay Somerset
Oops -- posted to wrong group. This one has proper group & followup
header.
On Wed, 26 Dec 2007 17:58:10 -0500, Jay Somerset
