Corrupt registry repair
M
Hi my daughter's computer 'cannot load the hive (file)
\systemroot\system32\config\SOFTWARE...' and has been unable to repair itself.
I have tried system restore and I cannot remember the exact message but
basically there appear to be no restore points to go back to.
Can I do anything e.g. edit or repair or restore the registry using the
command prompt? And if so how?
Is there any solution?
Thanks,
Mike
D
Darrell Gorter[MSFT]
Hello Mike,
There are backup copies of the registry in the
\windows\system32\config\regback folder
You can try replacing the ones in the config folder with the ones from the
regback folder.
Rename the ones in the \windows\system32\config folder first
Change directory so you are in the \windows\system32 folder
ren system system.bak
ren software software.bak
ren sam sam.bak
ren security security.bak
Then
copy c:\windows\system32\config\regback\system
copy c:\windows\system32\config\regback\software
copy c:\windows\system32\config\regback\sam
copy c:\windows\system32\config\regback\security
All four registry hives should be replaced at the same time even though you
are only having issues with one of the hives, they are a unit, they are not
intended to be replaced individually, there may be issues later if one of
the hives is rolled back and not the others.
Thanks,
This posting is provided "AS IS" with no warranties, and confers no rights
| >Thread-Topic: Corrupt registry repair
| >thread-index: AcmrM9Le48VgOb39RF6mGYf9m+wa9A==
| >X-WBNR-Posting-Host: 65.55.21.8
| >From: =?Utf-8?B?TWlrZQ==?= <Mike@xxxxxx>
| >Subject: Corrupt registry repair
| >Date: Sun, 22 Mar 2009 14:19:02 -0700
| >Lines: 16
| >Message-ID: <660C7DE9-AE57-4688-8826-084A50B13056@xxxxxx>
| >MIME-Version: 1.0
| >Content-Type: text/plain;
| > charset="Utf-8"
| >Content-Transfer-Encoding: 7bit
| >X-Newsreader: Microsoft CDO for Windows 2000
| >Content-Class: urn:content-classes:message
| >Importance: normal
| >Priority: normal
| >X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.3168
| >Newsgroups: microsoft.public.windows.vista.performance_maintenance
| >Path: TK2MSFTNGHUB02.phx.gbl
| >Xref: TK2MSFTNGHUB02.phx.gbl
microsoft.public.windows.vista.performance_maintenance:33433
| >NNTP-Posting-Host: tk2msftibfm01.phx.gbl 10.40.244.149
| >X-Tomcat-NG: microsoft.public.windows.vista.performance_maintenance
itself.
| >Thanks,
| >Mike
M
Thanks very much Darrell.
I'm not quite as computer savvy as I may sound: if I get the command prompt
up do I firstly type
then
etc.?
Then do I
>cd\windows\system32
followed by
etc?
Also I am having difficulty getting the command prompt at the moment as the
last option in the recovery module (I think it was the recovery module, from
memory: it seems to come up when the self repair fails) is not to load the
command prompt, although that option has appeared once or twice before. So
I'm not sure if I can get back to the command prompt or not at the moment.
Mike
""Darrell Gorter[MSFT]"" wrote:
> Hello Mike,
> regback folder.
> ren sam sam.bak
> Then
> Thanks,
> | >Lines: 16
> | >MIME-Version: 1.0
> | > charset="Utf-8"
> | >Importance: normal
> | >Priority: normal
> itself.
> | >Thanks,
> | >Mike
M
I have now managed to follow your instructions, with a little help from my
son....but the same error 'cannot load the hive' etc has recurred.
> Hello Mike,
> regback folder.
> ren sam sam.bak
> Then
> Thanks,
> | >Lines: 16
> | >MIME-Version: 1.0
> | > charset="Utf-8"
> | >Importance: normal
> | >Priority: normal
> itself.
> | >Thanks,
> | >Mike
D
Hello Mike,
What is the size of the software file in c:\windows\system32\config folder?
If the registry file is corrupted and the backup registry files are
corrupted, the options are limited.
You may need to backup your data and reinstall Windows or you have a backup
of the OS, restore that backup.
Thanks,
| >thread-index: Acms7oYqjWVyDEJ6QKaaWJt1SMDhsw==
| >X-WBNR-Posting-Host: 207.46.193.207
| >References: <660C7DE9-AE57-4688-8826-084A50B13056@xxxxxx>
<DANGBh#qJHA.3688@xxxxxx>
| >Subject: RE: Corrupt registry repair
| >Date: Tue, 24 Mar 2009 19:08:01 -0700
| >Lines: 76
| >Message-ID: <E7FD12E0-4532-4EBA-B88D-BD45DCF293A0@xxxxxx>
| >MIME-Version: 1.0
| > charset="Utf-8"
| >Importance: normal
| >Priority: normal
microsoft.public.windows.vista.performance_maintenance:33495
| >NNTP-Posting-Host: tk2msftsbfm01.phx.gbl 10.40.244.148
my
| >> Hello Mike,
the
| >> regback folder.
| >> ren sam sam.bak
| >> Then
though you
are not
of
| >> Thanks,
rights
| >> | >Lines: 16
| >> | >MIME-Version: 1.0
| >> | > charset="Utf-8"
| >> | >Importance: normal
| >> | >Priority: normal
repair
| >> itself.
but
the
| >> | >Thanks,
| >> | >Mike
4
Location
Louisville
Hello
I just built a computer this night, and when i booted it up, it ran smooth for about 10 minutes. i just remember getting comfortable then looking up and the screen was black. i left it alone for a minute but eventually reset it. now it ALWAYS takes me to the "Windows failed to boot..." blah blah you know start windows normal, safe mode, etc. i have tried all those, but it always loads for a minute and then says something about not loading the "hive" file and dumping physical memory. but the screen flashes so fast i cant read it. then it reboots and does the whole thing over and over. now keep in mind, i built this so i used Windows Vista Basic for Builders. i tried to start my computer with the system disk in it, but it did nothing. im getting rather frustrated...
    AMD Phenom II X4 940 Deneb 3.0GHz 4 x 512KB L2 Cache 6MB L3
    ASUS M3N78 PRO AM2+/AM2 NVIDIA GeForce 8300 HDMI ATX AMD
    G.SKILL 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F
    (Onboard) NVIDIA GeForce 8300
    (Onboard) Realtek ALC1200 (8 Channels)
    Phillips 32" LCD
    Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drives
    RAIDMAX SMILODON ATX-612WB Black 1.0mm SECC Steel ATX Mid To
    I built this computer Tuesday, June 16, 2009
D
Donald
So you havn't done much customization on that machine, right? I suggest you
to boot with the installation CD and perform a system repair. If that does
not work, you can reinstall it. It will be done in about thirty minutes
anyways and save you a lot of headache. If the problem happens again, you
may need to check the BIOS firmware and ensure it is the updated one (you
can try to use the manufacture applications to flash your BIOS firmware) and
run some hardware test (memory and hard disk, etc) to see whether they are
in good condition and compatible with Vista. It is always good to have a
backup of registry so you can restore it with any sort of startup.
How to automatically repair Windows Vista using Startup Repair
www.bleepingcomputer.com/tutorials/tutorial148.html
For hardware testing, you can download memtest to check your memory and use
some manufacture testing tool to check your hard disk. There are some
software specifically designed for testing all your hardware.
Best of luck.
"thecelloslave" <guest@xxxxxx-email.com> wrote in message
news:1e5002fda9be691586c1d0407ced3232@xxxxxx-gateway.com...
> Hello
> thecelloslave
S
Spirit
#8
The first thing I would do is unplug and totally reseat all cards and
memory. UnPlug and reseat all cables, do NOT just snug them up.
Then try startup repair.
"Donald" <donaldhuang@xxxxxx> wrote in message
news:EC60D9B5-56B7-4E81-8884-7D4CC8245CEA@xxxxxx
> you to boot with the installation CD and perform a system repair. If that
> does not work, you can reinstall it. It will be done in about thirty
> minutes anyways and save you a lot of headache. If the problem happens
> again, you may need to check the BIOS firmware and ensure it is the
> updated one (you can try to use the manufacture applications to flash your
> BIOS firmware) and run some hardware test (memory and hard disk, etc) to
> see whether they are in good condition and compatible with Vista. It is
> always good to have a backup of registry so you can restore it with any
> sort of startup.
> use some manufacture testing tool to check your hard disk. There are some
> Best of luck.
>> Hello
>> thecelloslave
