Create script to gather workstation logs
S
Sear S
I have trouble putting a VB script together to gather 2 different log files
located on c:\root of each workstation
Thanks for your help!
Sam
T
Tom Lavedas
On May 19, 8:06 am, Sear S <Sear [email protected]>
wrote:
> Hi,
> Sam
Show us what you have and describe the problems in some detail -
include OS specifics and any error messages encountered. Few of us
can/are willing to do all the work for you. Plus, that's almost
impossible, anyway, without more knowledge of your specific working
environment, security policies, etc.
_____________________
Tom Lavedas
S
Sear S
Hi Tom,
I am not very good with VB script that's why I just wondered if there was a
script out there corresponding my needs...
OS: Windows XP Pro
Script function: Should be to gather some workstation log files located
right on C root...we are talking maybe about 10 workstations max.
I know it's too much to ask...but If there is anything out there then let me
know
Thanks guys
Sam
"Sear S" wrote:
> Hi,
> Sam
T
Tom Lavedas
On May 19, 10:45 am, Sear S <[email protected]> wrote:
> Hi Tom,
> I am not very good with VB script that's why I just wondered if there wasa
> OS: Windows XP Pro
> I know it's too much to ask...but If there is anything out there then letme
> know
> Thanks guys
> Sam
Assuming you have domain admin rights on the machines in question,
they can be accessed through their C$ (D$, etc) shares (unless they've
been disabled), something like this ...
sServerNames = "server1,server2,server3,etc"
sLogName = "ourlog.log"
sDestination = "C:\Logs\"
with createobject("scripting.filesystemobject")
for each server in split(sServerNames, ",")
sLogPath = "\\" & server & "\C$\" & sLogName
if .fileExists(sLogPath) then
.copyfile slogpath, sDestination & server & sLogName
end if
next
end with
This is "air code" to demonstrate the approach. I have not tested it,
so I may have missed a fine point of syntax or such, but the general
approach is valid. See the WSH down-loadable documentation and Script
Center samples for more information on how to solve your problem:
WSH 5.6 documentation download (URL all one line)
http://www.microsoft.com/downloads/...48-207D-4BE1-8A76-1C4099D7BBB9&displaylang=en
TechNet Script Center Sample Scripts (URL all one line)
http://www.microsoft.com/downloads/details.aspx?FamilyID=b4cb2678-dafb-4e30-b2da-b8814fe2da5a
Tom Lavedas
S
Sear S
Hi Tom,
Thanks, however 2 questions about sdestination and slogpath
Is Sdestination as target machine (s) destination path?
Is sLogname path the path from where the log file that needs to be copied
from?
Thanks
Sam
"Sear S" wrote:
> Hi,
> Sam
T
Tom Lavedas
On May 25, 1:14 pm, Sear S <[email protected]> wrote:
> Hi Tom,
I'm not certain what you mean be the word 'target', so I'll just try
expanding on my intention.
It is the place where you want the log file(s) to be copied TO. That
is the destination for the copied files.
> from?
Not quite. It is the name of the log file to be copied (the
destination name is the same, except prefaced with the name of the
server it came from), but the actual source PATH is contained in
sLogPath (built from the server's name and the sharepoint name).
Finally, realize that I meant this as an example from which you could
craft your final solution. It may or may not suit your needs as
written. I don't have a comprehensive understanding of what your
environment is or of what you want to accomplish, exactly.
HTH,
Tom Lavedas
S
Sear S
Hi Tom,
Ok let me explain in details what I exactly want to accomplish:
I need a script that I can use to gather a log file from a number of
workstations...in total 40 workstations
The log file is located on C:\logfilename of each one of those workstations...
I have full admin access to those PCs therefore permissions won't be an issue!
Once I ran the script, I would like it to copy all those log files from
those machines and put them somewhere on a shared drive for me...
I hope that clarifies a little bit my point
Thanks
Sam
> > Hi Tom,
> > from?
> HTH,
> Tom Lavedas
T
Tom Lavedas
On May 27, 3:57 pm, Sear S <[email protected]> wrote:
> Hi Tom,
> Thanks
> Sam
OK, from what you said, you just need to change the value of sLogName
to be "logfilename" and the sDestination content to be "\
\Storageservername\locationfoldername\" and complete the list of
server names.
sLogName = "logfilename"
sDestination = "\\Storageservername\locationfoldername\"
end if
next
end with
Of course, 40 server names would be a problem in the SET statement, so
a file list (one name per line) would be better, something like
this ...
sServerNameFile = "c:\some\local\folder\Servernames.txt"
sServerNames = .OpenTextFile(sServerNameFile, 1).ReadAll
for each server in split(sServerNames, vbNewLine)
.copyfile slogpath, sDestination & server & "_" & sLogName
end if
next
end with
It should create one file for each server in the specified location.
Tom Lavedas
S
Sear S
HI Tom,
A BIG THANK YOu this works perfectly!!
If the file name on some servers is different than the one mentioned in the
Slogname section then can I add more file names as below?
> sLogName = "logfilename,logfilename2, etc..."
> end if
> next
> end with
> > Hi Tom,
> > Thanks
> > Sam
> server names.
> end if
> next
> end with
> this ...
> end if
> next
> end with
> Tom Lavedas
T
Tom Lavedas
On May 28, 10:30 am, Sear S <[email protected]> wrote:
> HI Tom,
> >     end if
> >   next
> > end with
> > > Hi Tom,
> > > Once I ran the script, I would like it  to copy all those log filesfrom
> > server names.
> >     end if
> >   next
> > end with
> > this ...
> >     end if
> >   next
> > end with
> > Tom Lavedas
If there are just a few differences, that could be handled as Select
Case in place of the simpler "IF .FileExists(...)" statement,
Select Case True
case .fileExists(sLogPath1)
.copyfile slogpath, sDestination & server & sLogName1
case .fileExists(sLogPath2)
.copyfile slogpath, sDestination & server & sLogName2
case .fileExists(sLogPath3)
.copyfile slogpath, sDestination & server & sLogName3
end if
Of course, the three file name variables would need to be defined
earlier in the script.
If there are many different names, it might be easier to add them as
part of the ServerNames text file, on lofgilename per server, as
in ...
server1, logfilename.log
server2 anothername.txt
server3
etc.
To simplify things a bit, a blank for the name could be used to
indicate the use of a default name. Then the code might look like
this ...
sDefaultLogName = "logfilename"
for each sLine in split(sServerNames, vbNewLine)
sLine = trim(sLine)
if not (sLine) = "" then
aTemp = split(sLine & " " & sDefaultLogName)
server = aTemp(0)
sLogName = aTemp(1)
end if
end if
next
end with
Tom Lavedas
