Crosslinked directories
A
Alan Biddle
I seem to have "cross linked" directories. For example:
C:\Documents and Settings\Alan\AppData\Roaming\SatPC32\Kepler
C:\Users\Alan\AppData\Roaming\SatPC32\Kepler>
However, they reference the same contents. That is, if you copy a
file to one, it appears in both, and if you delete a file in one, it
disappears from both.
There are literally dozens of them, similar to the above except for
the "\SATPC32\Kepler" part which changes depending on the program
data.
The OS is Vista Business, SP2. Other than being a little confusing,
it does not seem to cause any problems, except my backup files are
larger because of this.
Any help on fixing this, if it needs to be fixed, would be
appreciated.
Alan
M
Michael Walraven
Alan
I assume you are using Vista.
'Documents and settings' is not used by Vista, however a link is there to
allow older/XP programs to run with their previous default paths.
This link means there are two ways to get to many of your documents, each is
valid but you should NOT use the 'Documents and settings' in general.
That you are discussing this path implies that you have elected to view
hidden/system protected files and directories. That is OK, but you run the
risk of encountering or accidently changing internal system files that can
make life more interesting than expected. I personally leave the display of
system/hidden files off unless I am specifically looking for something.
Specific to your question: It does not need to be fixed, operation is
correct for Vista.
Michael
"Alan Biddle" <ALANBIDDLE70@newsgroup> wrote in message
news:spt0e59rtr2beolbd2f2pevccofor7d1ne@newsgroup
> data.
> appreciated.
> Alan
K
Ken Blake, MVP
On Thu, 22 Oct 2009 10:25:38 -0500, Alan Biddle
> data.
> appreciated.
These are *not* crosslinked directories, and there is nothing to be
fixed. You are talking about virtual folders. Virtual folders don't
actually exist as folders; there are merely pointers (like shortcuts)
to real folders.
Ken Blake, Microsoft MVP (Windows Desktop Experience) since 2003
Please Reply to the Newsgroup
