Custom Combobox in WPF
A
askaile
hi
I wud like to create a custom combobox using custom control in WPF. My
requirement is that, all items should be checkbox items, with each
item has a hot key associated with it. I would like text in text area
to be string by concatenating all hot keys. ie. suppose i have
selected two items Grey(with hot key G) and Black (with hot key B).
then text in combobox text box should be GB.
Thanks for replies in advance
Amandeep
L
Laurent Bugnion, MVP
askaile wrote:
> Hi
> Im still waiting for anyone to help me as im new in WPF. So any help
> will be appreciated.
> Thanks in advance
> Amandeep
I recommend you to post your question in the MSDN WPF forum at
http://forums.microsoft.com/MSDN/ShowForum.aspx?ForumID=119&SiteID=1
Greetings,
Laurent
Laurent Bugnion [MVP ASP.NET]
Software engineering, Blog: http://www.galasoft.ch
PhotoAlbum: http://www.galasoft.ch/pictures
Support children in Calcutta: http://www.calcutta-espoir.ch
