Customer Control Lessons Leaned So Far...
J
All:
I have been developiing a simple (what I thought was simple) custom
control (derived from UserControl). The basic functionality is that of
a Jeopardy-style game square --- it should be a rounded rectangle that
is filled with a gradient brush that sizes itself to the grid cell
(parent) to which it is placed.
What I have learned...
* A UserControl can only have one child element. I originally used a
Rectangle, but then could not add the question/answer text (no way to
add a Label or TextBlock, etc.). Laurent Bugnion suggested using a
container for the single allowed child and add children this way. I
tried this and used a Canvas - it worked, somewhat...
* I added 2 children to the Canvas -- a rectangle and a TextBlock.
Originally, the rectangle was marked as
Horizontal/VerticalAlignment="Stretch", with no specific Width and
Height specified. This worked when the Rectangle was the direct child
of the UserControl - but failed to display when the Rectangle was the
child of the Canvas. Apparently, the Rectangle needs to have a specific
Width and Height specified - which prevents Stretch from working...
aaaarrrggghhhh
Any insights and comments welcome. I hope the above helps others..
John - jpuopolo
D
Douglas Stockwell
Hi John,
Canvas is only used for absolute positioning, that is, where you specify
Left, Top, Width and Height properties. Horizontal/VerticalAlignment are
unused.
I think you just need to explore the other subclasses of
System.Windows.Controls.Panel, depending on how you want to lay out the
elements, at least one of (or a combination of) Grid, StackPanel, WrapPanel,
or DockPanel should suit your needs.
- Doug
"john" <puopolo@gmail.com> wrote in message
news:1165160006.502441.322460@n67g2000cwd.googlegroups.com...
> All:
> aaaarrrggghhhh
> John - jpuopolo
J
Doug:
Thanks for the advice -- a StackPanel seems to do the trick... My only
challenge now is to figure out if it is possible to round the corners
of the StackPanel -- will play around with various configurations and
post the results.
Best,
John (jpuopolo)
Douglas Stockwell wrote:
> Hi John,
> unused.
> - Doug
> > All:
> > aaaarrrggghhhh
> > John - jpuopolo
L
Laurent Bugnion
john wrote:
> Doug:
> post the results.
> Best,
> John (jpuopolo)
Sure, use a Border:
<StackPanel>
<Border CornerRadius="10" BorderBrush="Red" BorderThickness="5">
<TextBlock Text="Hello" />
</Border>
</StackPanel>
HTH,
Laurent
Laurent Bugnion, GalaSoft
Software engineering: http://www.galasoft-LB.ch
PhotoAlbum: http://www.galasoft-LB.ch/pictures
Support children in Calcutta: http://www.calcutta-espoir.ch
