DATA D drive?
45
Hi could somebody explain how i use my DATA D drive . When i open MY Computer i have a Acer C drive with 69.7 GB and a DATA D with the same GB , it may seem a stupid question but i don't have a good knowledge of computers
Cheers Dave
Its simply the way Acer chose to setup the PC, & name the drives.
You can locate/move your data files to the D drive, or use D for any
backups, or when installing a program choose Custom install & install to D
rather than C
"david boylan" <guest@xxxxxx-email.com> wrote in message
news:611a51a51c3bc0958c9e5b2367acaaa3@xxxxxx-gateway.com...
> computers
> Cheers Dave
> david boylan
R
Rick Rogers
Hi David,
D: is simply storage space. Think of it as having two bookshelves instead of
one to store books on. Create folders as desired on it to store files of
your choosing. If desired, you can also remap things like your User
Documents files to automatically go there (just right click the folder,
choose properties and check the location tab).
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
> computers
> Cheers Dave
> david boylan
Vince65
1
Hi David,
Best of Luck,
Microsoft Most Valuable Professional
My thoughts Life and other stuff
> computers
> Cheers Dave
> david boylan
My C: drive was almost full, so i decided to put my pictures into the D: drive to free up space and maybe speed up things.Now the Pictures folder has been replaced with Data D: in the start menu,and I can no longer import pics from a camera or memory card.However i can open a folder to view pics then move to other folders (documents for instance)...but I want my Pictures folder back.Also when I open Data D: there are two picture folders there in the favourite links menu, which I don't like.They both link to the same pic files.I wish I'd never bothered.
