dATA eXECUTION pREVENTION
D
dennthemen
I have a UK accounting system (Sage). When I try to install updates Vista
comes back and tells me it has terminated the program for DEP reasons.
Do you know how I get around this please.
R
Richard Urban
I would get around it by obtaining a copy of the program that was properly
designed for Windows XP - let alone Windows Vista.
Your program is trying to execute code in a protected area of memory. This
is exactly what some malicious software does. This action was not desirable
under XP and it is prevented since XP service pack 2 and also in Vista.
Can it be turned off? YES!
Would I do it or recommend it? NO!
http://support.microsoft.com/kb/875351
http://support.microsoft.com/kb/875352
http://technet2.microsoft.com/Windo...4101-44c3-a294-4da1bd1ef2271033.mspx?mfr=true
Richard Urban
Microsoft MVP
Windows Desktop Experience
"dennthemen" <dennthemen@xxxxxx> wrote in message
news:9624DBF0-3848-4F49-8D70-969C9C8586BF@xxxxxx
1,823
See if your motherboard has NX or data exception switch in the BIOS. If your motherboard, supports DEP at the hardware level use it. I disabled DEP because of my old applications don't support it. No newer versions that support DEP. Microsoft will always tell you to leave it on. I don't know of many newer applications that fully support DEP.
    16GB DDR667
    SAS RAID
