Databinding and Commands
  • Thread starter Corrado Cavalli [MVP]
  • Start date
C
Working on May CTP...
I'm trying to bind to a static class :
public static class MyCommands
public static RoutedCommand ClearAll;
static MyCommands ()
InputGestureCollection ic = new InputGestureCollection();
ic.Add(new KeyGesture(Key.P,ModifierKeys.Control));
ClearAll = new RoutedUICommand("ClearAll", "clear", typeof(Window1),ic);
public static string Name
get { return "ok"; }
And trying to use it on a Menuitem
<MenuItem Name="mi1" Command="c:MyCommands.ClearAll"" Header="x:Static
c:MyCommands.Name}" />
Everything works fine if i remove static operator on classe definition, any
idea why?
Corrado Cavalli [Microsoft .NET MVP-MCP]
UGIdotNET - http://www.ugidotnet.org
Weblog: http://blogs.ugidotnet.org/corrado
=?Utf-8?B?VGhlUkhvZ3Vl?=
There are RoutedCommand and ICommand samples in the SDK:
http://windowssdk.msdn.microsoft.com/en-us/library/ms771540.aspx
The negative with the link is that it takes you to a 72 megabyte download to
Beta 2 samples. The positive is that you get a lot of samples you can easily
search through to find code samples...the RoutedCommand sample built on the
latest WPF release.
The following syntax may be of interest to you:
<CommandBinding Command="{x:Static custom:Window1.ColorCmd}"
Executed="WindowColorCmdExecuted"
CanExecute="ColorCmdCanExecute"/>
If the architecture of routed command doesn't work, you will need to
implement an ICommand which is easy to do...and there is an SDK sample too :)
"Give a man a fish, and you feed him for a day. Teach a man to fish, and you
feed him for a lifetime." ...I think I prefer..."Learn to fish, and feed
yourself for a lifetime."
> idea why?
