Solved Dedicated system memory for graphics card
brummyfan
Brummy
731
Location
Birmingham
Hi
I am upgrading the memory to 2GB from 1GB, could someone please tell me whether I can change the Dedicated system memory from 64MB to 128 MB or just leave it as it is. I have attached the current info.
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello Brummy,
Since it appears to be a integrated graphics chip, then you may be able to adjust how much dedicated system memory you want to use in BIOS for it.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi brummyfan,
I don't think that you can change this (unless the option is there in your BIOS - check the manual).
Dedicated graphics memory refers to memory that is included on a graphics card, whereas Dedicated system memory refers to memory that is assigned to an onboard graphics solution.
The Total available graphics memory is made up of Shared system memory and either of the above, depending upon whether you are using built-in graphics or a graphics card.
When you increase your main system memory, it is possible that the amount of Shared system memory will increase, but that depends on the system architecture and options available in your BIOS.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
brummyfan
Brummy
731
Location
Birmingham
Thank you guys, your detailed information much appreciated.
    Biostar
    Biostar MCP6P-M2
    CIBOX
    Hitachi 160GB
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
You're welcome Brummy. :)
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
