Deleting a file in use
A
Ashish
Is there any way in powershell to delete a file which is in use?
I tried move and delete and that didnt work.. Am looking at something in Win
API like MOVEFILE_DELAY_UNTIL_REBOOT
R
RichS
If the file is locked open you won't be able to delete it from PowerShell
during that session
Richard Siddaway
Please note that all scripts are supplied "as is" and with no warranty
Blog: http://richardsiddaway.spaces.live.com/
PowerShell User Group: http://www.get-psuguk.org.uk
J
Jason
A
Ashish
i created a Pinvoke code which calls MoveFileEx API for the same...seems like
it isnt happy taking values of long type. any ideas what may have gone wrong?
$domain = [AppDomain]::CurrentDomain
$name = New-Object Reflection.AssemblyName 'TestAssembly'
$assembly = $domain.DefineDynamicAssembly($name, 'Run')
$module = $assembly.DefineDynamicModule('TestModule')
$type = $module.DefineType('TestType')
[Type[]]$parameterTypes = [string], [string], [int64]
$method = $type.DefineMethod("MoveFileeX", 'Public,Static,PinvokeImpl',
[bool], $parameterTypes)
$ctor = [Runtime.InteropServices.DllImportAttribute].GetConstructor([string])
$attr = New-Object Reflection.Emit.CustomAttributeBuilder $ctor, 'kernel32'
$method.SetCustomAttribute($attr)
$realType = $type.CreateType()
[object[]]$args = [string]'F:\\dll\\abc.dll', [string]$null, [int64]4
$realType.InvokeMember('MoveFileeX', 'Public,Static,InvokeMethod',
$null,$null, $args)
> during that session
> Richard Siddaway
