deleting a ghost folder permanently
frodo66
1
hello, I downloaded a movie from the internet (ext.avi). However when i try to delete it, a message comes up saying that the file is being used by another progam and cannot be deleted. I checked on the internet and found a solution to this issue - by deleting a file form the windows register. It worked...for a while. Now whenever I restart my pc, the folder(empty) keeps appearing on my desktop. How do i get rid of it permanently?
patio
Vista Pro
403
KillBox.
Use with Caution...
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA
    200G Seagate SATA
    100G WD Caviar SATA
    80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2
    Dos 6.2;Win2K;XP; &
    Vista Ultimate 64Bit.
Dzomlija
Resistance is Futile
2,213
Location
South Africa
What is the folder called?
You can check the settings of program (uTorrent, FlashGet, Getright, etc...) that you used to download the AVI file to see whether or not it is re-creating that folder each time you boot. It is possible that the download utility has recorded that folder as the default desintation for downloads, and whenever it starts up, finds it missing and then recreates it.
Windows Media Player does this also for whatever folder you have specified for the default "Rip To" folder...
Also, whoever told you to delete stuff from the registry in order to delete a file is either lying or just not telling you the truth.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
bruce2
Vista Pro
618
Hi frodo66, welcome to the board.
Try to delete it in safe mode. If it still coming back up, what is suggested by Dzomlija is true.
Post back.
Bruce
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
