Deleting a shortcut to a program that no longer exists
S
Stevo
I installed a game it placed shotcut icon on desktop.
Game didnt install properly so uninstalled.
Now it want let me delete the shortcut as it says that it cant find the
program.
How do I delete this pesky shortcut?
There is no security info under that tab under properties it seems there is
no way to delete this shotcut file, this is rediculas!!
Can anyone help please thanks steve.
M
Malke
> program.
How are you trying to delete the shortcut? It sounds like you're
left-clicking on it and perhaps have your mouse set to single-click,
therefore the game is trying to run. Try right-clicking and then choose
"Delete".
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Brink
Staff member
mvp
Oklahoma, USA
Posts
32,400
I agree with Malke, but also try right clicking your desktop & click REFRESH. Sometimes Vista just doesn't refresh that quickly & the Icon shortcut is still visible even though it's not really there. Go figure.
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
D
DWHgreen
I also have this problem. I downloaded a program for a virtual site and
created a shortcut. I have thoroughly uninstalled the program files. Now when
I try to delete or remove the shortcut icon from my desktop either by
dragging it to recycle bin or by right clicking on it and selecting delete
from the drop-down menu, I get a message box telling me the shortcut icon
cannot be deleted because the file does not exist. I just want to get this
icon off my desktop. Does someone have the solution?
DWHgreen
> program.
B
Bogdan Florian
Try to open the shortcut... Windows will warning you that the shortcut link
is invalid and will ask you if you want to delete that shortcut.
Cheers...
> DWHgreen
> > program.
MEFF14
Posts
2
None of this information helps at all !!!!! I have the same problem as DWHgreen Please Help!! and sorry to bring up a old post but this has all the information that dose not work and the same problems i have
hkim295
Posts
1
#8
I had the same exact problem after uninstalling a program and trying to delete that oh so annoying shortcut on my desktop by dragging it to the recycling bin.
What you can do is right-click your desktop and click "refresh". After doing this, my shortcut disappeared. Good luck!
