deleting htm and gif files
when attempting to delete htm and gif files that appear when I type in the
search task bar, I get a message that states cannot find file to remove it-
But it shows as using x amount KB
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hi JRA,
This is most likely from the index not having finished updating itself yet since it runs slowly in the background when the computer is idle or in low use. You can rebuild the index to force it to update now. This will show you how to.
http://www.vistax64.com/tutorials/69581-indexing-options.html
Another option is to disable the index to have accurate search results all the time. The only drawback is that it will take a little bit longer to run the search. You can always enable the index again if it is just to slow. This will show you how to enable and disable the index.
http://www.vistax64.com/tutorials/69564-index-enable-disable.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
