Deleting temp files
G
Gordon Biggar
I recently deleted some 2,000+ files from my Windows\Temp folder. I
remember - back in my Windows 2000 days - I set up a batch file that
executed on boot-up from the Start-up folder that deleted such files. What
would the equivalent procedure be for Vista Home Premium (64-bit)? Am I
able to duplicate that former procedure? Are there other temp files that
are created that I should be aware of for deleting purposes?
If I am unable to locate that former batch file, what is the appropriate
command line for deletions?
Gordon Biggar
Houston, Texas
B
Badger
Try downloading - CCLEANER
It will delete all kinds of temp files and others.
You can also set it up to run at startup.
"Gordon Biggar" <colonel_biggs@newsgroup> wrote in message
news:#ZRfR4C3KHA.4540@newsgroup
> What would the equivalent procedure be for Vista Home Premium (64-bit)?
> Am I able to duplicate that former procedure? Are there other temp files
> that are created that I should be aware of for deleting purposes?
> Gordon Biggar
> Houston, Texas
G
Gordon Biggar
I note that the application does some registry cleaning, which procedure a
number of folks in this forum recommend strongly against. Can this be
bypassed?
GB
"Badger" <jerrymcm@newsgroup> wrote in message
news:OwfpPdE3KHA.556@newsgroup
>> Gordon Biggar
>> Houston, Texas
Chase
americano
1,571
Location
Merced & Monterey, CA
You can also delete temporary files through the following procedure:
  • Press the Windows key + R
  • Type:
    Code:
    prefetch
  • Press ctrl + A
  • Press shift + delete
After you have cleared the prefetch folder you can repeat the process with the
Code:
temp
and
Code:
%temp%
folders.
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
G
Guest
del %tmp%\*.* /s /q
news:%23ZRfR4C3KHA.4540@newsgroup
> Gordon Biggar
> Houston, Texas
On 14 Apr 2010, "Gordon Biggar" <colonel_biggs@newsgroup> wrote
in microsoft.public.windows.vista.general:
> I remember - back in my Windows 2000 days - I set up a batch file
> that executed on boot-up from the Start-up folder that deleted
> such files. What would the equivalent procedure be for Vista Home
> Premium (64-bit)? Am I able to duplicate that former procedure?
Yes.
> Are there other temp files that are created that I should be aware
Yes, lots. It's safest to use Windows' own Disk Cleanup utility:
<http://windows.microsoft.com/en-US/windows-vista/Delete-files-using-Disk-Cleanup>
Ccleaner can find more stuff you might consider expendible.
<http://www.piriform.com/ccleaner>
G
Gordon Biggar
I am not familiar with the Prefetch folder. It has about 200 files in it,
all created within the last few days, but nothing older than that. Somehow,
these files must be self-deleting, or deleted on a time basis.?
GB
"Americano" <guest@newsgroup-email.com> wrote in message
news:1aa2a121227d9293783facf5f23afef5@newsgroup-gateway.com...
> YOU CAN ALSO DELETE TEMPORARY FILES THROUGH THE FOLLOWING PROCEDURE:
> - Press the *Windows key + R*
> - Type:
> Code:
> prefetch
> - Press *ctrl + A
> - Press* shift + delete*
> with the
> Code:
> temp
> and
> Code:
> %temp%
> folders.
> Americano
> *Trying the Same Thing Over, and Expecting a Different Result =
> Insanity*
> http://www.vistax64.com/images/styles/vista/buttons/reputation.gif
> -*don't forget to say thanks, tip my scales!*-
C
Camper
#8
news:uTaW7rE3KHA.4336@newsgroup
>bypassed?
> GB
Yes.
Camper
B
+Bob+
#9
On Wed, 14 Apr 2010 22:22:53 -0500, "Gordon Biggar"
>bypassed?
>GB
You can easily set the options in ccleaner to leave the registry as
is. It will clean out lots of stuff you don't really need. Be sure to
pay attention to the settings if you don't want to remove things like
MSIE history and such.
Chase
americano
1,571
Location
#10
GB
I clear my prefetch, temp, and %temp% folder everytime I turn on my computer. I also run a Piriform CCleaner cleaning, as well as the registry issues scanner.
    HP Pavilion Elite
    6.O GB RAM
    1440x900 & 1440x900
    HP: M/N:M-SBQ133
    Comcast: 20 MB/S
G
Gordon Biggar
#11
"So simple, even a child can do it."
Thanks for the lead.
GB
"Nil" <rednoise@newsgroup> wrote in message
news:Xns9D5BB4117BF0nilch1@newsgroup
> Yes.
G
Gordon Biggar
#12
Does %temp% refer to any temp folder, or is this a specific folder?
GB
news:19a0994f64509bfd56d85c07dcb9d0f5@newsgroup-gateway.com...
>> it,
>> Somehow,
>> GB
> I clear my -prefetch-, -temp-, and -%temp%- folder everytime I turn on
> Americano
> Insanity*
> folder?
One specific folder. Type SET at a command prompt to see where it is.
You will also find a TMP variable that might point to a different
location.
J
John Jay Smith
#14
> Gordon Biggar
> Houston, Texas
ccleaner
Chase
americano
1,571
Location
#15
> folder?
location.
In other words; yes, it is a separate folder than the temp's. :)
    HP Pavilion Elite
    6.O GB RAM
    1440x900 & 1440x900
    HP: M/N:M-SBQ133
    Comcast: 20 MB/S
Lin894
4
Location
Lancashire
#16
I use ccleaner and you dont have to use the registry cleaner bit if you dont want to, its a separate procedure.
Re deleting prefetch folders, ccleaner deletes old ones (tho not sure how old) and Ive been told that you shouldnt delete the recent ones.
On 16 Apr 2010, Lin894 <guest@newsgroup-email.com> wrote in
> recent ones.
There's really not much good reason to delete the Prefetch files unless
you are about to defrag or something. They will just be re-generated by
Windows at its first opportunity.
